INSTALL FRONT CLEARS
Old Feb 27, 2001 | 10:20 AM
rino_2kmax's Avatar
hey what did you people use to install ur clear lenses
i used a screw driver with a towel on the rear ones but got fustrated casue i couldnt get it out and i went crazy and bent my car and chipped one for the side marker clips
now thta i got my new fronts and dotn want to have the same problems what did you guys use ?????????????????????????
Old Feb 27, 2001 | 10:29 AM
kafene's Avatar
the fronts are much easier
at least it was for me.. i know what you mean about the rears. i had the same thing happen. i chipped one of the rears too. look up the intstructions on how to replace the bulb in the owners manual. it shows the screwdriver w/ the cloth going from the rear of the light. it comes out much easier than the rear. pretty simple.
kafene.
Old Feb 27, 2001 | 10:46 AM
kpark's Avatar
All the ends of the sockets where the clear corners fit into are crushed in and chipped due to my sloppy install. I'm pretty mad about it, but what can I do?
Old Feb 27, 2001 | 11:32 AM
blackY2Kmax's Avatar
Re: the fronts are much easier
kafene.
kafene is right - the fronts are way easier. I got the fronts off in about 30 seconds. Follow the manual like kafene said - they pop out so easily. I also chipped both my stock rears so I understand your frustration, but don't worry about the fronts.
Old Oct 27, 2001 | 10:14 AM
zgrm100's Avatar
Re: Re: the fronts are much easier
Originally posted by blackY2Kmax
[I]
i cant find my maxima manual anywhere. can some1 please help me out, i dont want to chip anything
Old Oct 27, 2001 | 12:01 PM
eortiz15's Avatar
See this
http://www.5thgenmaximas.com/clearinst.html
Old Oct 27, 2001 | 01:50 PM
Greg's2kGLE's Avatar
To get the rears out, put the screwdriver (with a towel) on the fatter part of the lense. Ok, to make that more clear, if you are on the driver's side, take the lense out from the left side. If you are on the passenger side, take it out from the right side. Hope that is clear.
Oh and it looks like that you have the rear clears judging from your sig pic
Old Oct 27, 2001 | 03:30 PM
kjpierce's Avatar
i just put mine in yesterday. i used a screwdriver and a towel. i folded the towel over, doubled it up, so there would be less a chance for a scratch or indent in the body. on the rears try to push a little more than pry. but be careful and steady. oh yeah, and be patient , it will come.
good luck!
Old Oct 27, 2001 | 08:02 PM
jameszzz
try to push the marker toward the other end while working on the screw driver. That worked for me. By the way if you got your rear markers from autodynamics you don't have to worry about it when you want to take them out again cuz they are kinda loose after you put them on(just feel it, but it's no big deal).
W7
JoshG
21
Sep 4, 2015 09:04 PM
DZN13
Aug 24, 2015 11:00 AM
Team STILLEN
Aug 10, 2015 04:29 PM
yat70458
Aug 3, 2015 01:16 PM
