Tranny Update
Tranny Update
After the tech told me yesterday that they were most likely going to put in a new tranny into my 00 se auto because it was slamming into gear, he told me to drop it off this morning because nissan told them to run some tests on the tranny. Anyway, he called this evening and told me that he had ordered a drop resistor and that this should take care of all of my problems. He said it should be here monday.
Is nissan beating around the bush of not trying to give me a new tranny because im almost out of warranty or will the drop resistor make any improvements?? Also, my car idles kinda high. At like 35 mph it would be at 2,000 rpms which is not right, the tech saw it and also said that it's not right.
Please help so i know how to respond to him on Monday.
Thanks guys.
Thanks guys.
Originally Posted by Mick Max
A lot of guys here have caused an open in the drop on purpose.
I gave her a try too and it sounds like what it could very well be.
Is the 1-2 almost a slam bang kind of shift with the 2-3 a little softer?
If he is right, then a new drop resistor says the old one was defective(it failed) and any damage to the tranny because of you driving it around like this is a failure of the power train itself = they should be responsible for replacing the tranny if the new drop resistor does not cure it.
I think if it was the drop resistor, at heavy to WOT it would shift crisply, do you recall how it shifted under those conditions?
Just be sure to talk real calm, slow, keep your right hand in your jacket pocket, mass murderer face on, so they know u mean business.
SHIFT_woosh
SHIFT_woosh
SHIFT_woosh
SHIFT_woosh
Originally Posted by milellie111
At WOT it shifted ok but at like half throttle, the thing would take forever to downshift. I mean i could rev it for like 7 seconds or so and it would not down shift, just keep on going to about 3400 rpms and then all of a sudden drop ,like it was late or something. Can there be other possible damage done to the tranny and not only just the drop resistor??
Originally Posted by Matto357
That's actually sounds like the TSB for the Tranny. Did they replace the solenoids and TCM?
they didn't do anything to my tsb or thottle body when they did my TSB ether...but solenoid alone fixed the problem for me. sounds like your's is a more serious problem.
why don't you just call Nissan directly. lay it all out on the line. "my warranty is about up. you are aware of the problem. are you going to screw me if i go over 60k or are you going to do what is needed to fix this?"
stop going through the dealership. they WILL screw you if you let them. deal with Nissan! then go tell the dealership what they said and have Nissan contact them if needed.
litch
123
Jan 4, 2024 07:01 PM
mkaresh
Mar 12, 2018 06:48 PM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
