50K mile maintence...
Old Dec 12, 2003 | 09:09 PM
higney85's Avatar
Im very close to 50K miles in my 2K se. It has the original battery,plugs,belts,hoses. I am planning on swapping out the battery,belts,hoses, coolant,spark plugs, and change out my brake pads if needed. I keep up with the air filter and the tranny/engine oil (M1). Anything else I should/could do? Things to avoid? I'm doing this stuff tommorrow I think. I am home right now for xmas break at college so I really can't do maintenece more then 2x a year.
Old Dec 12, 2003 | 10:16 PM
VMaximus02's Avatar
I would also replace pcv valve/ps&brake fluids, clean the throttle body housing and also the fuel injectors w/B&G products?
Old Dec 12, 2003 | 11:03 PM
panda_1's Avatar
IM IN THE SAME BOAT ITS TIME TO DO MY MAINTAINENCE ON MY 2K SE, BUT I HAVE ALREADY REPLACED MY PLUGS, OIL, AIR FILTER AND CLEANED MY INJECTORS.
Old Dec 13, 2003 | 07:14 AM
mclee45's Avatar
did you guys open the engine up to clean the injectors or just use one of those additives you add to the gasoline?
Old Dec 13, 2003 | 10:57 AM
MaxSerg's Avatar
Use additive. And try to use a good product that really works.
PS. Do we really need to replace the hoses and spark plug wires at 50K miles?
Old Dec 13, 2003 | 11:09 AM
RoNx777's Avatar
Last i remember 2k Max uses coil packs, no more wires...
Turbonut
46
Oct 21, 2015 08:28 PM
JoshG
51
Sep 21, 2015 10:41 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
hntwhttail
Sep 12, 2015 03:43 PM
crazyespn
Sep 3, 2015 01:30 PM
