need underdriving facts
Old Dec 14, 2003 | 05:05 PM
MmaximaSE01's Avatar
I want to get a underdrive pully but want to know if its really a good idea. I dont know where the harmonic balancer is on the 3.0 but if its on the crank pully i guess it takes 20,000 miles off the life of the engine. also is it safe to underdrive the al/tnator water, power steering pumps???
thax
Old Dec 14, 2003 | 05:15 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
thax
harmonic balancer is not on the pulley. udp are safe to run and even some audiophlies run them with their systems. if you have something extreme then it might not be a great idea. the only pulley available is the crank pulley, which will underdrive the compressor and alternator. power steering is run off another belt which a pulley is not available for. only issues i have had with my udp pulley were noise from subpar belts and improper initial install which led to the death of 2 tensioner pulleys.
Old Dec 14, 2003 | 06:10 PM
Mick Max's Avatar
Wild at Hurt
Sloppymax is right,
But mine worked great form the get go. I think it is the perfect mod.
Quicksilver is putting a group deal together as we type, so check that forum.
I see you have 6 posts so first it is welcome aboard. Then a reminder to stay away from thr RVM one. The UR on the other hand is a beauty IMHO
Old Dec 14, 2003 | 09:23 PM
twotone's Avatar
thax
1 quick thing.. you plan on SCing? If you are.. then forget the UDP.
Old Dec 14, 2003 | 10:01 PM
PhxBlue's Avatar
MK3 Supra and Focus ST
Ive had a UDP for a while now w/o problems.
Old Dec 15, 2003 | 03:47 AM
MaDdFLaSheR's Avatar
hey phx.. does the udp make a noticible difference? did you ever time your car quarter mile b4 and after?
Old Dec 15, 2003 | 05:45 AM
MannyNJ2k2max's Avatar
is it better to get the stock pulley sized one? I noticed UR has two different ones
Old Dec 15, 2003 | 04:41 PM
Mick Max's Avatar
Wild at Hurt
An engineer friend of mine who has been racing all his life says
taking this amount of weight off the crank probably frees up
6HP in the lower gears.
Even when I am running lap top, GPS, Rear wind def, fogs and h lites
nothing ever dims and it always starts. So with underdriving, ya wont notice.
With multiple trunk filling amps, then think about the non underdrive.
Old Dec 16, 2003 | 12:42 AM
thomasd cook's Avatar
I've got 2 amps. 1's a 500/1 JL Audio with 2 12SL7's and the other amp is a 300 watt JVC on high's. I'm getting a cap soon and probably swapping the battery to a blue top. Do ya'll think that if I get a UDP it will rob my power and not be worth it.
I've got 2 amps. 1's a 500/1 JL Audio with 2 12SL7's and the other amp is a 300 watt JVC on high's. I'm getting a cap soon and probably swapping the battery to a blue top. Do ya'll think that if I get a UDP it will rob my power and not be worth it?
Old Dec 16, 2003 | 06:36 AM
Mick Max's Avatar
Wild at Hurt
thomasd cook,
With what you list I would go non underdrive just to be safe.
You will still get the majority of the benifit by lightening the crank.
doctorpullit
Jul 20, 2019 09:31 PM
doctorpullit
Dec 12, 2015 09:39 AM
Turbonut
46
Oct 21, 2015 08:28 PM
fastcarny
Oct 12, 2015 07:06 AM
carid
Sep 9, 2015 05:06 AM
