View Poll Results: how do I...?
You may post new threads.
0%
You may post replies.
0%
Voters: 0. You may not vote on this poll
Help with my alarm...
Old Dec 18, 2003 | 07:10 AM
cpakolipse's Avatar
I have a 2001 Max SE, and I am having trouble with my alarm. I think it's in "valet" mode, which mechanics keep telling me over the phone. They tell me that there's either a way with the key chain, or there should be a switch underneath the dash by the steering wheel? I have tried pressing the unlock and lock at the same time, and other possible sequences with the key chain, but no luck. I looked under the steering wheel, maybe I missed it, but I coudn't see anything. I'm wondering if I take off the battery for a second, will it reset the alarm? Does anyone have any suggestions towards this matter..?
Old Dec 18, 2003 | 07:15 AM
GuZo's Avatar
what kInd of alarm is it
i dont believe stock alarms have valet mode
Old Dec 18, 2003 | 07:19 AM
cpakolipse's Avatar
I'm not sure which type it is.. but the alarm is def off becuase when I lock the doors, and open them the alarm isn't going off.
Old Dec 18, 2003 | 08:00 AM
Max's Max's Avatar
If it is the factory alarm (nissan key fob), opening the door with the key will disable the alarm. If you lock the doors with the key, wait 30 seconds before reaching in the car and opening the door.
Old Dec 18, 2003 | 08:07 AM
cpakolipse's Avatar
right, but I know that the alarm is definitely disabled, because the sounds of turning off the alarm is not there anymore like it used to be. I think I might have unknowingly set some type of code through the "nissan key fob".
Also, when I mentioned that I locked the doors, I was inside the car and pressed the alarm to "ON", and then I unlocked the door, and no alarm.
by the way, thx for the quick replies... but I'm still wondering if I undo the battery for a second, will it reset the alarm...?
Old Dec 18, 2003 | 10:27 PM
zgrm100's Avatar
try holding the door unlock and lock button for 3 seconds.
Old Dec 19, 2003 | 06:51 AM
cpakolipse's Avatar
Yeah I tried that, but it makes the alarm silent when I lock it...
Old Dec 19, 2003 | 07:14 AM
ZAJOBA's Avatar
What do you want alarm to do ?
I never had my alarm going on, its like keyless entry for me. Maybe if someone broke the window it went on, but thats it.
Old Dec 19, 2003 | 07:22 AM
PWRLFT's Avatar
If you have an after market alarm you should also have an extra led somewhere. With mine that light is off when it's in valet mode (or a steady on not sure). When I got my alarm installed they never showed my where the switch was, I had to go back and make them point it out to me. They put mine on the side of the dead pedal back about three inches, it's a small metal button.
To turn my alarm off I turn off the car and press that button within 30 seconds.
To turn it back on, after turning the car off press the button within 30 seconds.
My button is pretty easy to hit while getting out of the car by mistake, but it sounds like your factory alarm is disabled as well. Weird
Buy the way taking the battery off will reset your ECU and I think that's bad (you have to reprogram it, other threads on that)
Old Dec 19, 2003 | 07:41 AM
studman's Avatar
If you have an aftermarket DEI alarm (Viper, Clifford, Sidewinder, etc), try this:
1) Open the driver's door
2) Press the arm button (doors should try to lock)
3) Press the disarm button (doors should try to unlock)
4) Press the arm button again (the LED should go off)
Then close the door and try to arm the car again. It should be out of valet mode.
Old Dec 19, 2003 | 08:06 AM
cpakolipse's Avatar
Actually guys, I'm not too sure if it's a factory or if it's aftermarket, because I bought it at the dealership and they installed it, I'm guessing it's not. I have an LED light on the front panel next to my steering wheel, and it's constantly on right now, when before this mishap, it used to blink. I tried to look for the button underneath and couldn't differentiate what or where the button was because of all the wires. But I'll see if I see a metal one tonite.
Hey PWRLFT,
I'm alittle lost when you say "dead pedal back", where exactly is that?
Old Dec 19, 2003 | 10:54 AM
PWRLFT's Avatar
The dead pedal is where your left foot should be while you are driving, it's that piece of leather sewn into the floor.
In my picture below the dead peddle is the U and the . is the button.
Automatic:
U. [ ] []
Manual:
U. [] [] []
Anyway if you stick your head down where your break peddle is and look left you should see it. By the way LED on all the time it's in valet mode. Flashlight will help.
Good Luck, and if you still can't find it do what I did pull into the service center park where they can't ignore you, tell them you just want to ask a quick question. Don't forget to smile.
Good luck
Old Dec 19, 2003 | 10:59 AM
cpakolipse's Avatar
PWRLFT
hahaha,
thx man, I'll definitely try and see what I can do, and if doesn't work, I'll ride there with a smile-
Old Dec 19, 2003 | 12:30 PM
studman's Avatar
cpakolipse: If you have that red light and it is lit solid, my method posted above should work to get it out of valet mode. But for future reference, you need to visit your dealer and find out where they put the little button.
Old Dec 19, 2003 | 12:35 PM
MannyNJ2k2max's Avatar
True! (if its a DEI) I have a Viper
Or you can turn the key to "on " position and press the disable button mounted under your dash
Old Dec 22, 2003 | 07:47 AM
cpakolipse's Avatar
thx guys, I finally fixed the issue, by finding a tiny dot of a button underneath the wires.
Fundem
24
Jan 2, 2014 07:43 PM
maxxxdout
50
Sep 2, 2011 09:49 AM
bigakphilly
May 10, 2011 01:09 PM
bigakphilly
Feb 23, 2011 09:57 PM
bigakphilly
Dec 12, 2010 02:21 AM
