PhantonGrip LSD conv. kit
Old Dec 19, 2003 | 10:44 AM
MyownNismo's Avatar
Future Camaro SS owner
Has anybody without a LSD thought of doing this. They have two types one for manuals and one for autos.
http://www.phantomgrip.com/product_l...p?make=Nissan#
Old Dec 19, 2003 | 10:57 AM
The Legend's Avatar
Im interested but I have other mods I want to do first. Also what other parts would I need or is everthing included?
Old Dec 19, 2003 | 10:59 AM
PWRLFT's Avatar
How do I know if I have a LSD or not?
Old Dec 19, 2003 | 11:22 AM
MyownNismo's Avatar
what year do you have I know 00's don't have a LSD 01's have it in the AE I don't know about non AE's and I think all 02-03's 6spd's have them and don't know about 02-03 auto's.
Old Dec 19, 2003 | 11:33 AM
PWRLFT's Avatar
i got an 03 auto.
Old Dec 19, 2003 | 12:12 PM
BigDogJonx's Avatar
This is pretty much similar to what I got done custom. But that plate looks cheap. Mine was of much higher quality and all the gears were cryo treated.
Now to do this on the manual you got to get the differential out of the 5spd which takes about 20mins once you got the tranny out.
Dixit
Old Dec 19, 2003 | 12:35 PM
Jaws's Avatar
i got an 03 auto.
Only some 02/03 6 speeds have it. You're SOL.
Old Dec 19, 2003 | 06:02 PM
PWRLFT's Avatar
ouch, well would that thing above stop massive wheel spin when it's raining out? I don't know if both wheels are spinning or if it's just one. If they are both spinning then I don't think it will help much?
What do you think?
Old Dec 19, 2003 | 06:29 PM
PearlWhtMaX2000's Avatar
What is an lcd????
Old Dec 19, 2003 | 08:22 PM
Fezzik's Avatar
To tell if you have LSD on a 6speed is to check and see if you have the silver looking race pedals instead of the normal black. The silver race pedals came with the LSD while the black ones came with the 6speeds without the LSD.
Old Dec 19, 2003 | 08:30 PM
00MaxSE's Avatar
Pointy Elbows
I could definately use LSD. I'll probably wait until I pay off my car to do it though. Cuz I'm broke.
Old Dec 20, 2003 | 07:06 AM
What is this?? and what does it do??
Old Dec 20, 2003 | 09:14 AM
Jaws's Avatar
A limited slip differential distributes the torque evenly to the drive wheels. With an open differential configuration, the wheel with the least amount of traction provides the forward thrust. I'm sure you've heard the term Posi-trac, its the same thing. The great benefit of this system is the ability to power out of a tight corner with LSD, where an open differential car would light up the inside tire. Its also helpful in moving away from a stop in very slippery conditions.
Old Dec 20, 2003 | 10:31 AM
Bulldawg's Avatar
I am pretty sure that all 2k2-2k3 6 speed have LSD, but only some come with HLSD....the ones with the pedals have HLSD.
Old Dec 20, 2003 | 07:15 PM
Jaws's Avatar
No, the only LSD available is the HLSD. As you mentioned, it only came on some 2k2/3s.
Old Dec 20, 2003 | 07:23 PM
MyownNismo's Avatar
I think I am going to get this once I get my stage II VB Mod and get it all done at the same time.
Old Dec 20, 2003 | 07:35 PM
maximadave's Avatar
detailerdaveb@gmail.com
2K1 AE 5-speeds had VLSD (Viscous Limited Slip Differential)
2K2-2K3's 6-speeds with AE pedals have HLSD (Hellical Limited Slip Differential)
Old Dec 21, 2003 | 09:18 AM
Bulldawg's Avatar
So, what is a good test to see if you have LSD other than the pedals? I have always understood it, that if when accel. hard if you leave two tire tracks, then you have LSD. and when accel. hard around a turn if you leave two then you have HLSD. Is there a better test? Because last time I was at the track I had both tires spinning on the launch, and I don't have AE pedals
Old Dec 21, 2003 | 09:45 AM
WILLSE's Avatar
turn ur wheel to either side while doing a burn out and only one will spin. my car does the same in a straight line and i dont have HLSD.
will
Old Dec 21, 2003 | 01:20 PM
mjg's Avatar
mjg
It's pretty funny that some of you guys don't even know if you have it or not, wouldn't care either way if someone had not told you, yet would want it if someone told you that it's something that can be added on to the car.
No particular offense to anyone, just an observation. Why not just leave the differential alone.
Old Dec 21, 2003 | 01:47 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
I got a Phantom Grip in my ride, trying to fit my HS headers off a 3.5 and dynoing it... TechnoSquare is getting my spare ECU reprogrammed... and then the stroked 3.0 is going in.
Old Dec 21, 2003 | 02:19 PM
MyownNismo's Avatar
For one I know that I don't have a LSD and I want to know if anybody has one. Which was my question. I want one cause I want traction to both wheels instead of one since and it would really help in the snow.
Old Dec 21, 2003 | 02:28 PM
The Legend's Avatar
is there a considerable difference with the phantom grip than without? how long have you had it on?
Old Dec 21, 2003 | 03:41 PM
97MaximaGLE's Avatar
Does it work for 2k3 autos? Would it fit right?
Old Dec 21, 2003 | 04:27 PM
MyownNismo's Avatar
That you would have to ask them. All I know is that it says 95+.
Old Dec 21, 2003 | 05:31 PM
I have the GREEN SPRING setup in my Maxima, and I must say I have much higher confidence in this LSD than a AE 5spd I just drove not too long ago. It might be cause I am on Ground Controls and Konis vs stock suspension, plus my tires are 245-45-17 Azenis on Enkei RPO1s vs stock AE tires/wheels. I can power out of the turns quickly without a hint of wheel spin. I used to be able to push the front end out when entering power on into the turn and would end up understeering like crazy. Now the car just rips through the corner pretty well. I'm trying to build a pretty good overall performance sedan with enough power for the suspension/brakes to handle. I got JIC Magics on the way so I will need to hurry up on the 3.6L buildup. There are 2 diff types of springs that U can get with the PhantomGrip, I got the green springs which are the most hardcore of all. I love it, install took me little to no time
Old Dec 22, 2003 | 05:46 AM
Lumbee1's Avatar
2K2 and 2K3 6 spds had VLSD (Viscous Limited Slip Differential) stock. HLSD was the upgrade to that.
Old Dec 22, 2003 | 08:38 AM
MattBeaty's Avatar
Could you notice a difference in the amount of torque steer after you installed the LSD? If it reduces torque steer, I would consider buying one. Does the install require a lift, or can it be done with only a jack and jack stands?
Old Dec 22, 2003 | 08:41 AM
BigDogJonx's Avatar
Definetely helps torque steer and wheel hop cause it forces both tires to spin instead of one wheel hopping and causing torque steer.
BTW the install is not a simple put it on jacks and pop something in. You gotta open the tranny up, so that means dropping the tranny and then taking out the diff and installing the sandwich adapter inside the diff. Then sealing up the tranny and reinstall the tranny.
Dixit
Old Dec 22, 2003 | 09:16 AM
The Legend's Avatar
Anyone had any experinces with the auto "treme" version of the PG LSD?
Old Dec 22, 2003 | 10:52 AM
Jaws's Avatar
I am 100% certain that they only LSD available on the 2k2/3s is the HLSD - if a gen 5.5 does not have a HLSD, then it has an open diff. The VLSD was available on the AE editions and earlier Canadian spec cars.
Old Dec 22, 2003 | 01:44 PM
panda_1's Avatar
id dont get it if i add the lasd convresion kit its allows me t put the lsd in or it is the lsd?
Old Dec 22, 2003 | 03:48 PM
BigDogJonx's Avatar
If you put this conversion piece in IT IS then LSD. Nothing more needed.
Old Dec 22, 2003 | 09:03 PM
ohhhhhh so basically it is posi?? how much is install usually??
Old Dec 22, 2003 | 10:08 PM
96_vqmax's Avatar
BlackBird are your tranny 5sp right?Cause I don't think they had one for the 6sp yet.
Old Dec 22, 2003 | 10:28 PM
Mine is a 3.0L GXE 5spd 2001 vintage, but I'm building up a 3.6L motor out of a 3.0L. I got projects all over the place and my own engine gets pushed aside for other engine swaps. Just got a G20 and put a SR20DET into it.
Old Dec 23, 2003 | 03:22 AM
panda_1's Avatar
Damn In That Case Where Can I Get One?
Old Dec 25, 2003 | 12:59 AM
you can get one directly from PhantomGrip.com for 299 bux, add in 29 bux for the spring kit- which comes with the normal Gold springs, or the hardcore GREEN springs. Since I like road racing my car and auto crossing it, I decided to just leave the green springs in- don't feel like taking the tranny out and taking it apart to install new springs before every race ! I can't tell ya what the milder GOLD springs feel like, at the next Nissan meet here in IL if anyone wants to feel the diff kickn, ya can feel it personally.
Apr 16, 2020 05:15 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
Pied
Sep 26, 2015 03:29 PM
