Help with Idle Control System
Old Dec 19, 2003 | 01:14 PM
BEEI30's Avatar
Where is the Idle Control System located at? Is it between the TB and MAF? I hear sounds like the butterfly valve is open and air is bring sucked in. My car stays at 1500rpms during idle when shifted in park and neutral.
Old Dec 19, 2003 | 01:38 PM
Igor911's Avatar
right at the throttle body. Take off the intake and you will see it. You may want to clean your TB while your there....not a bad idea
Old Dec 19, 2003 | 02:19 PM
BEEI30's Avatar
So it is inside the throttle body? or behind the butterfly valve. i cleaned it already a couple months back.
Old Dec 19, 2003 | 03:57 PM
BigDogJonx's Avatar
Are you talking about the IACV? If so it is UNDER the throttle body opening.
What I would do is relearn the Idle Air Volume Learn. That might bring the idle back down. If not, then take it to the dealer.
Dixit
BkGreen97
Apr 2, 2016 05:47 AM
RWCreative
Sep 21, 2015 11:01 AM
97_GXE
20
Sep 17, 2015 08:12 PM
carid
Sep 9, 2015 05:06 AM
dcam0326
Sep 7, 2015 07:26 AM
