Tranny slip / warranty ???
Old Dec 21, 2003 | 07:20 PM
2k2nyc's Avatar
My 2k2 tranny is slipping pretty bad. It's currently at 26.5k miles. I added 4 quarts of synthetic ATF @ 25k miles. Will Nissan give me a problem for adding the synthetic ATF? Should I do a complete tranny flush w/ regular oil before I take it in?
Old Dec 22, 2003 | 08:52 AM
talkinghorse's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
I'm sure you've done this, but first make sure the transmission is not low on fluid. Assuming the fluid level is OK, the slipping you refer to is fairly common with these cars...there's a "sticky" on this forum which highlights the Nissan TSB for this problem. Since dealers are the way they are, I suspect that if you wave a red flag in front of them and advertise that you changed the fluid, they will be quick to blame that as the root cause of your problem. If the fluid you used is Dextron III rated (synthetic or not), it meets Nissan requirements...so there should be no cause to drain/refill with conventional fluids.
My recommendation is that you simply report the problem to your dealer and let them sort it out...in order to refuse to honor the warranty, they would have to prove that the lubricant you used was the direct cause of the problem.
Hope this helps....let me know how you make out.
Old Dec 22, 2003 | 09:08 AM
2k2nyc's Avatar
I had used Amsoil, (ring a bell?)
Old Dec 22, 2003 | 11:34 AM
maximadave's Avatar
detailerdaveb@gmail.com
Don't tell the Nissan dealer you have aftermarket tranny oil. If you do, they may deny a replacement tranny for you. You are under warranty, take it to the dealer.
Old Dec 22, 2003 | 11:38 AM
kevc5's Avatar
cahnge the fluid back to stock before you bring it in...
Old Dec 22, 2003 | 11:43 AM
2k2nyc's Avatar
I guess I'll change it back, just to play it safe.
Old Dec 22, 2003 | 11:57 AM
NYC TAR's Avatar
don't go to star nissan, just because it close to you. What dealer are doing to?
Old Dec 22, 2003 | 12:14 PM
2k2nyc's Avatar
STAR, I know, they blow.
Do you recommend anyone else?
Old Dec 22, 2003 | 01:19 PM
NYC TAR's Avatar
major nissan in garden. I know they have a very good track record for nissan survey. I never been turn down for any warranty work. good people over there
Old Dec 22, 2003 | 01:24 PM
2k2nyc's Avatar
thanks bro
Old Dec 22, 2003 | 01:28 PM
2k2nyc's Avatar
Where exactly is that located???
Old Dec 22, 2003 | 01:41 PM
NYC TAR's Avatar
here is add and tell http://nissanofgardencity.com/frames...ice_department
and ask for service adv shan-nek ( what ever his name is)
Old Dec 22, 2003 | 03:16 PM
Ding Ding Ding!
It's not the oil. AMSOIL ATF surpasses warranty requirements as it meets/exceeds D-III specs. I seriously doubt your servicing dealer will have the oil analyzed to determine if you have serviced it with something other than Nissan-matic D. Many dealers use Brand X fluids in place of the OEM fluids, anyway. I recently serviced an '00 I-30 for a guy and the local Infinity dealer told me to use D-III.
I'm not advising you lie about it, but if you raise the point about servicing the transmission yourself, it raises another issue that you don't need to introduce. Just tell them the problem you're having with it and let them figure it out.
Old Dec 22, 2003 | 05:31 PM
NissanMasterTec's Avatar
Wow, here is another case of...
If it ain't broke , don't fix it
Old Dec 22, 2003 | 05:44 PM
irish44j's Avatar
retired moderator
So what you're saying is that we should all leave our cars completely stock, since that's the way they are made.....and since they are not "broke" we shouldn't do anything to them.........this would be a very boring forum if that was the case.
since you are a "master tech", why don't you offer 2k2nyc some constructive advice instead of just telling him he should have left the car stock....
So I assume your car is completely stock, mastertec?
Old Dec 22, 2003 | 06:14 PM
03BlkSETE's Avatar
Good advice but I would be very cautious taking advice from NissanMastertec. Often his advice is useless (as witnessed above) and more often than it should be (for an alleged master tech), it's just plain wrong.
Old Dec 22, 2003 | 06:20 PM
irish44j's Avatar
retired moderator
yeah I have seen that.....i'm just making fun of him. what is the Nissan dealer in St.Petersburg...better not go there if you want good service!
irish44j's Avatar
retired moderator
See the other thread on "RSB fell off" for more evidence of stupidity.
Old Dec 23, 2003 | 05:55 AM
2k2nyc's Avatar
Originally Posted by talkinghorse
Ding Ding Ding!
I know it's not the oil. My tranny was a little off before I added synthetic, but after adding it, the problem became a bit more noticeable.
Thanks for the input. I'm going to flush out the existing oil and replace it with OEM, just to play it safe.
Old Dec 23, 2003 | 05:58 AM
2k2nyc's Avatar
..STFU homo..
Old Dec 23, 2003 | 07:19 AM
desperado_45's Avatar
There is no way they can tell if you added different fluid! Unless they have a chemical lab!!! But if your going to do it yourself and want to play it safe go ahead, I just wouldn't spend $100 to have it done.
Old Dec 23, 2003 | 10:37 AM
brianc's Avatar
You guys really need to read the magnusson moss warranty act, again!
http://www.granatellimotorsports.com/magnusonmoss.htm
Basically if a dealer demands you use specfic oil, filters, etc or your warranty is void they have to provide said items free of charge.
As long as what you use meets or exceeds original specs you're good to go.
Brian
Old Dec 23, 2003 | 12:27 PM
2k2nyc's Avatar
Thanks brianc, good to know.
Old Dec 23, 2003 | 12:38 PM
PAPA SMURF
nice advice from a nissan "master tech"
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
pktaske
Sep 4, 2015 08:40 AM
