2000 MAX loose brake light connections?
Old Dec 23, 2003 | 02:26 PM
Jerry13's Avatar
Anybody else have this problem? My driver side brake light connection is loose, for everytime I close trunk or go over a bump it goes out. I then have to remove the panneling in the trunk and tap on it so it goes back on. ANY SUGGESTIONS to fix this permanently?
Old Dec 23, 2003 | 02:29 PM
Zero Deuce SE's Avatar
I would say that either your bulb is loose in the socket or the socket itself is damaged. Try another bulb first to see if that solves trhe problem.
Old Dec 23, 2003 | 04:18 PM
Max2000's Avatar
take out the bulb and look closely.... I had that happen to me.. and finally the bulb burn out.. I thought it was the bad connection.. but it was not.. it was the bulb that is slowly dying
Old Dec 24, 2003 | 05:21 AM
CCS2k1Max's Avatar
If the bulb was replaced, it's likely it wasn't properly snapped into the socket. Being an all glass bulb, people are overly careful with it. Make sure you hear the bulb click in place.
Old Dec 24, 2003 | 05:31 AM
ryand.white's Avatar
Check the bulb as they all said. Same happened to me until the bulb just went out.
Old Dec 24, 2003 | 05:46 AM
SoonerFan's Avatar
Cletus
same here. thought it was a bad connection. it went out a few times and tapping it fixed it. then it finally went out. i replaced it and no more problems.
Old Dec 24, 2003 | 08:36 AM
KCMichaelM's Avatar
Seventhed ? It's the bulb almost ready to burn out... Just replace them both b/c it happened to me 2 weeks apart on both bulbs.
JMag90
Aug 25, 2015 09:17 AM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
Samedi
Aug 13, 2015 04:05 PM
