stainless-steel VS. Aluminized steel "Y" pipe
Old Dec 26, 2003 | 11:47 AM
fahad_600's Avatar
what are the advantages for the stainless-steel Y-pipe over the Aluminized steel ?
other than it won't rust, are there any advantages that's worth to pay the +$50 for the stainless-steel ??
I want to get a Y-pipe from www.warpspeedperformance.com, but I still haven't decide which one to choose ??
also what do you think of Warpspeed Y-pipe ?
Thanks,
Old Dec 26, 2003 | 11:49 AM
PAPA SMURF
Thanks,
i dont know that anyone makes a y-pipe for the 04 engine...
double check that...
Old Dec 26, 2003 | 11:53 AM
SeaFoam2DMax's Avatar
Oh hi....
His is a 3.0 engine, I personally got the stainless steel because that was all that mine came in. Mine is a cattman, not warpspeed but i think the idea is the same. If your concerned with the length of life, i would probably get the stainless.
Old Dec 26, 2003 | 11:56 AM
PAPA SMURF
oh sit...my badd...
Old Dec 26, 2003 | 12:03 PM
-Red-'s Avatar
I think the US equivalent to his car is probably the I30, so the only thing he needs to do is verify whether he needs a "Cali" or "Fed" spec pipe. Then again out in the middle east it may be a completely different
Old Dec 26, 2003 | 12:12 PM
fahad_600's Avatar
yeah, I think it's I30 with 5 speed tranny,
My car has two precats, and one main cat, so it's Cali spec, right ?
I want to order the y-pipe tomorow, so the only advantage for the stainless steel, it will last longer?
Thanks,
Old Dec 26, 2003 | 12:16 PM
KCMichaelM's Avatar
Thanks,
Yep... It looks prettier when you first put it on, but they all look the same after a few months.
Old Dec 26, 2003 | 12:19 PM
fahad_600's Avatar
how much HP increase I should expect from the y-pipe mod ??
my car is stock, and it has 3,000 mile .
Old Dec 26, 2003 | 12:36 PM
Loe max's Avatar
realistically people have seen 8-17fwhp. I don't quite understand why there is such a difference. A way to find out if you have a Fed or Cali spec is to check how many O2 sensors you have. 2=Fed, 4= Cali. The sensors are plugged into the front of the cylinder banks. I don't have the picture but hopefully someone can post it for you.
On a side note, its good to know that I can purchase an I30 stateside and do a 5speed conversion on the 2nd gen I30
Old Dec 26, 2003 | 02:39 PM
fahad_600's Avatar
can you tell from these pics
Really appreciate your help,
Thanks,
Old Dec 26, 2003 | 04:50 PM
Loe max's Avatar
It looks to be a Cali-spec
Old Dec 27, 2003 | 04:30 AM
fahad_600's Avatar
I'll try to get under the car and take better pics,
Thanks,
Old Dec 27, 2003 | 06:34 AM
fahad_600's Avatar
I went today to an exhuast shop, and found out that I only have 2 O2 sensors, so it's Fed spec.
I will order stainless-steel Y-pipe from www.warpspeedperformance.com,
$260 shipped to NY, what do you think of the price and the product ?
Thanks alot for every one who posted
Old Dec 27, 2003 | 08:32 AM
Loe max's Avatar
cool, a couple things you will or might notice
1) more power of the bat, especially at mid-high range
2) VI secondary switch over (5,200rpms), the engine sound becomes alot more hard-edged and racier (Sorta like a chain saw cutting through wood)
3) might have some wierd hissing noise from the flex section
4) your exhaust note changes from a smooth rasp to a very soft rumble at idle. When you let off the gas or press in the clutch, you'll notice this even more.
Old Dec 27, 2003 | 08:39 AM
fahad_600's Avatar
Thanks man,
"Sorta like a chain saw cutting through wood"
this is cool
and for the flex section noise, I think WarpS. have a new flex section that won't make this noise, I hope it's true.
I will try to take a video of the car at idle and reving, to compare the sound, before and after.
Thanks alot,
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Quickywd01
Sep 21, 2016 09:36 PM
