Maglight mod writeup needed
Old Dec 31, 2003 | 02:53 PM
WHEELMAN_03_SE's Avatar
MAGLIGHT mod writeup needed for 4 d cell. search is off so i cannot get to it, if you have it i would apprieciate it, Thanks in advance
WHEELMAN
Old Dec 31, 2003 | 03:12 PM
thrasher's Avatar
1. Buy Maglite 4D Flashlight.
2. Buy Maglie mounting bracket.
3. Put mounting bracket in desired position, drill holes with pilot bit.
4. Insert screws with mounting bracket in place.
5. Insert flashlight.
6. Enjoy.
Old Dec 31, 2003 | 04:00 PM
asu174's Avatar
Clay Aiken has fancy genitals
What part of this "mod" were you having trouble with?
Old Dec 31, 2003 | 04:02 PM
2k3TitaniumSe's Avatar
Why do you always have to make fun, man?
Old Dec 31, 2003 | 04:04 PM
asu174's Avatar
Not making fun... Legitamite question.
Old Dec 31, 2003 | 04:11 PM
irish44j's Avatar
retired moderator
Here's what it looks like. Sorry for the bad pic (it's night time) and dirty car (it's winter).....just screw one bracket to the cross beam where the front of the seat mounts (2 screws). then put the Mag there.
Old Dec 31, 2003 | 04:12 PM
irish44j's Avatar
retired moderator
Or, you could get a "mini-maglite" and put it in your glove box or door map pocket.
Old Dec 31, 2003 | 04:22 PM
asu174's Avatar
I actually didn't even need the bracket for mine. It wedges prefectly in there. Actually, the rear of the maglite would have nothing to rest on in the rear if I did use the bracket.
Old Dec 31, 2003 | 04:30 PM
irish44j's Avatar
retired moderator
Yeah that works too....when it's in the bracket, the rear end of the light sits nicely...no rattles or anything. The bracket is tight enough holding it that the lite doesn't touch anything else, and it holds it up a little higher for easier access.
Old Dec 31, 2003 | 04:32 PM
asu174's Avatar
Yeah, my access is a bit restricted this way, especially with those damn power seat controls there. But it is as solid as can be wedged in there.
I would have gotten the brackets, but I didn't want to drill holes there in a fairly noticable spot along with the fact that no one in town sells the brackets.
Old Dec 31, 2003 | 04:40 PM
irish44j's Avatar
retired moderator
You can't even see the holes...they blend into the carpet....after I drilled them, I had a tough time finding them again to put the screws in!!!!
Old Dec 31, 2003 | 05:14 PM
gtbigup's Avatar
So what happens when you have to move ur seat to vaccum? Guess the light falls out.
Old Dec 31, 2003 | 05:44 PM
Just take off the light.
Old Dec 31, 2003 | 06:02 PM
asu174's Avatar
It wouldn't move, I don't think. Also, I don't really need to vacuum under the seat because there is a giant flashlight blocking anything from falling underneath.
Slamrod
Apr 10, 2016 05:24 PM
smplyamzng
Dec 13, 2015 01:19 PM
Maxima_Joe
Nov 25, 2015 08:19 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
TonyJr
Aug 20, 2015 12:14 AM
