Fix for Bass vibration
Old Dec 31, 2003 | 02:54 PM
bigk201's Avatar
I have a 2000 maxima with the Bose system. About 3 years ago I tried to fix the buzzing from the sub, but the fix was not completely successful. I finally got around to trying again, and this time it was a success.
The main problem is that the metal shelf under the back deck is way too thin and lacks support. (There was also a secondary problem which I'll get to in a minute.) The weakest area in the deck is generally in the open space between amplifier and the sub... about 2 or 3 inches rearward.
When I attempted a fix 3 years ago, I added a wood brace (in the trunk area) with screws securing it to the underside of the metal deck. The brace ran generally left to right (with some angle on it) in the open area mentioned above. I was on the right track, but this brace was not enough to make the buzzing go away. In my second attempt (last night), I added another 2x4 wood brace running from front to back, and I sandwiched wood blocks between it and the underside of the metal deck. Now when the sub wants to push down against the deck, it has something to push against.
The other thing that I discovered was that the cloth mesh covering the top surface of the sub was making noise. (Not the decorative grill.) I wouldn't have believed it if someone told me, but it actually was making noise. It turns out that this mesh stretches over time, and once it gets too big, it begins to resonate (flap) up and down. And it is especially sensitive to a particular frequency. If you need proof for yourself, just remove the decorative grill and watch the cloth while playing some aggressive base. I finally got brave and tore the cloth off, and it was a very good decision. The only negative to removing the cloth is that small grains of sand can find their way into the cone area. Removal of the cloth mesh is an easy fix that can be done in about 10 minutes. (The decorative grill is removed by prying upward on its front edge.)
Adding sound deadening material can be helpful and might diminish the buzzing problems, but the root cause of the noise is the weak metal deck that lacks structural support. If anyone would like to see photos of the wood bracing that I added, let me know. I'll try to take a few photos when I have some time. For those who might want to add the wood bracing to their car, I would estimate that you need to set aside about 8 hours. (Everything always takes longer than expected.)
Old Dec 31, 2003 | 04:35 PM
jattmax's Avatar
good job !!
I had a similar problem on my car, the read deck would flex insanely (no bose, eclipse 15's) i put 3 layers of dynamat extreme on the top, 1 on the bottom... that thing's mighty quiet now
Old Dec 31, 2003 | 04:40 PM
bigk201's Avatar
Originally Posted by jattmax
good job !!
What does dynamat look like? ...Is it glued on? Now that I have the support problem solved, some sound deadening would be icing on the cake. Where can I buy dynamat?
Old Dec 31, 2003 | 09:44 PM
ryand.white's Avatar
Save money and go to home depot and get some ice and water shield (for roofing purposes). you'll spend a lot less money with that option. it's all the same stuff. they just write dynamat on it and sell it for more money.
Old Dec 31, 2003 | 10:41 PM
jattmax's Avatar
your local stereo shop should carry it, i buy the dynamat extreme bulk packs, which i think is like 36 sq ft per box, for $150... thats my discounted price, but i dont think it would be much more than that... its basically a gluey sticky type material, you dont need glue or a heat gun like older versions, the outside is coated with aluminum for greater handling in heated enviroments. if you go to www.dynamat.com you can view pictures of the material, as well as installation instructions. you may be able to buy generic materials and get same results, but i've used dynamat personally and am satisfied with the outcome. hope this helps
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
leatherneck
Sep 30, 2015 09:16 PM
