Removing steering cover help
Old Jan 5, 2004 | 05:53 PM
crazymax's Avatar
Anyone know how to remove the steering wheel housing on the underneath side..I took the 3 screws out but the 2 parts are not coming apart..I am in the last process of installing the eye up for my steering wheel controls..any help would be appreciated..
Old Jan 5, 2004 | 06:07 PM
Zero Deuce SE's Avatar
I would be extremely careful messing around with the steering wheel parts. The airbag module is located in the area of the steering wheel controls. If you make a wrong move. KABOOM! You will get an expensive scare.
Old Jan 5, 2004 | 08:25 PM
futemv's Avatar
As I remember it, there were 5 screws from the underside, 3 holding the upper and lower parts together and 2 holding the lower part to something else. To be safer, unscrew all 5. At that point, its only a few clips holding the upper and lower parts together. These can be seperated with gentle pressure. To help with maneuvarability, lower the wheel tilt lever to let the wheel move. You shouldn't be able to trigger the airbag just by doing this, but don't go digging around too much once you got the cover off.
lowpost99
Oct 26, 2025 06:53 PM
Mar 12, 2020 12:06 AM
Max139617
Sep 20, 2015 07:25 PM
2kmaximel
Sep 10, 2015 08:13 AM
SusieQQ
Sep 9, 2015 12:14 PM
