To Those who Cleared out their 2k2+ HID's
Old Jan 9, 2004 | 06:38 AM
Igor911's Avatar
Hey Guys
I read somewhere that some of you used the flood lights at homedepot (which are glass) to cut out a 3 1/4" circle and use it for the turn signal peice.
How did you cut it out, what did you use or where did u take it to be done?
--Igor
Old Jan 9, 2004 | 06:43 AM
MAXINXS's Avatar
Some used a dremel to cut it out. Do a search for "Home Depot."
Old Jan 9, 2004 | 06:52 AM
Igor911's Avatar
I did and I read someone used a Dremel but they said they used some plastic light????
Then I read another thread with someone saying they used FLOOD LIGHTS, but they are glass.... You can't dremel glass?!?!
Old Jan 9, 2004 | 07:51 AM
limsandy's Avatar
It was plexiglas. Plexiglas is a plastic
~limsandy
Old Jan 9, 2004 | 07:55 AM
redstradic's Avatar
they are not glass. its a plastic. they are not exactly flood light lens. however, they are in the same section and these are the only type of lens replacement you can find at Home Depot.
Old Jan 9, 2004 | 07:58 AM
Igor911's Avatar
What is the product called because I purchased GE 90w Flood Lights.
Old Jan 9, 2004 | 08:01 AM
redstradic's Avatar
i have no idea what they are called. when i went to the outside lighting section, these were the only plastic replacement lenses i could find. they are a replacement lens to some type of light with a plug on the back of it. wish i could be more helpful.
Old Jan 9, 2004 | 08:05 AM
Igor911's Avatar
hmmm is it in the same section as the light bulbs?
Old Jan 9, 2004 | 09:35 AM
redstradic's Avatar
no, the Home Depot i went to had them in the outdoor lighting section.
Old Jan 9, 2004 | 09:44 AM
K Pazzo 6's Avatar
i got the same ones...dont have time to cut it...i'm going to take it to a local place today (since i'm getting my angel eyes today) that sells glass & plexi-glass & see how much they will charge to cut it....i'll let u know....
Old Jan 9, 2004 | 10:10 AM
redstradic's Avatar
Old Jan 9, 2004 | 10:16 AM
Igor911's Avatar
Thanks Guys...I'm going right now to look!
Old Jan 9, 2004 | 10:56 AM
Igor911's Avatar
OK UPDATE:
I went to home depot outdoor lighting section and NO LUCK!
Can someone please post the name or model # of this Flood Light or Outdoor Light? PLEASE!?!!?!
Thanks a bunch!
Old Jan 9, 2004 | 12:07 PM
Cutler's Avatar
Had them, wouldn't do it again.....
Old Jan 9, 2004 | 12:22 PM
PAPA SMURF
i got a question....what about NOT using a piece of plastic and just leaving the bulb exposed (just pulling out orange and NOT replacing it)
will this look ghetto?
Old Jan 9, 2004 | 12:38 PM
mjg's Avatar
mjg
i assume you get a big ticket for this. You need to have reflectors.
Old Jan 9, 2004 | 12:41 PM
jeepik's Avatar
the orange piece is not a reflector
in the front you only need to have a reflector on the side markers, not on the headlight
Old Jan 9, 2004 | 12:55 PM
redstradic's Avatar
OK UPDATE:
Thanks a bunch!
ill try to get a picture tonight of them.
Old Jan 9, 2004 | 12:56 PM
redstradic's Avatar
How do you figure and why wouldnt you do it again?
Old Jan 9, 2004 | 12:57 PM
redstradic's Avatar
headlights dont have reflectors!
Old Jan 9, 2004 | 01:06 PM
skandalouz's Avatar
i used a frosty plastic piece like a lot of others on .org... i have some uncut pieces leftover if u want that.... and also i have some clear pieces that are cut... and uncut if u need that as well...
Old Jan 9, 2004 | 01:17 PM
LithiuMax
I have no plastic piece there - just took the orange out and left it open. Check homepage for pics. I think it looks good.
Old Jan 9, 2004 | 01:24 PM
MannyNJ2k2max's Avatar
Looks good Ilya
I may do the same when I install my DDE's (1/12) - I assume you used chrome bulb there- Do you have a name/or place where I can get'm?Thanx
Old Jan 9, 2004 | 01:48 PM
Igor911's Avatar
Please post ASAP!!!!
Thanks alot!
Old Jan 9, 2004 | 01:55 PM
Gooey's Avatar
just buy whatever that looks like its gonna work its not that hard...its just plastic
Old Jan 9, 2004 | 02:02 PM
Igor911's Avatar
the thing is at my homedepot they dont have JACK!
I'm going to another loc. now, I'll keep you all posted
Old Jan 9, 2004 | 02:26 PM
LithiuMax
Manny, those are the stock bulbs that came with the car.
Old Jan 9, 2004 | 02:27 PM
really.....no very visible....
Old Jan 9, 2004 | 03:02 PM
Triple8Sol's Avatar
I miss the .org!
I remember reading that these lights came in a bag or something...and they're pretty cheap.
Also, when you dremel them out, apparently you need to make a couple notches or something?
Old Jan 9, 2004 | 03:09 PM
MaxDoogie's Avatar
when I cleared mine, I just left the piece off...BTW, the bulb that comes in there stock is clear and lights up yellow enough to be considered amber...This was told to me by a cop...The only problem is is it is super bright and angled upwards...But noone will miss me when I have my turn signal on
Old Jan 9, 2004 | 04:18 PM
Igor911's Avatar
OK I found the bagged lights, 2 for ~$7.00
I used a dremmel to cut it out and sand it down to 3 1/4"
Here are pics of the lights and one is already cut out
Old Jan 9, 2004 | 04:26 PM
scmaxima2k's Avatar
Hey you got a part number off those. I seem to remember someone posting a part number and manufacturer but now I cant find it. Thanks.
-Steve
Old Jan 9, 2004 | 04:33 PM
redstradic's Avatar
looks good. just make sure to put the three notches in it so it lays flat against the opening and so it wont turn on you once you line up the lens with the one above it.
Old Jan 9, 2004 | 04:41 PM
2k3TitaniumSe's Avatar
How do you put that piece back on? Super Glue?
Old Jan 9, 2004 | 05:00 PM
Igor911's Avatar
Model # of Lights from Home Depot: Malibu ML11P2
Here is what the completed project should look like:
Old Jan 9, 2004 | 05:21 PM
limsandy's Avatar
Thanks for the part number, Igor.
~limsandy
Old Jan 9, 2004 | 05:55 PM
Igor911's Avatar
~limsandy
NP, Goodluck finding them, took me 2 trips hehe
Old Jan 9, 2004 | 06:38 PM
Triple8Sol's Avatar
I miss the .org!
I went and bought them today at Home Depot. The part # Igor listed above is actually incorrect. It's MLD11 (not P) and it cost just under $10 with tax.
Old Jan 9, 2004 | 07:25 PM
KiLLeR2002se's Avatar
Eat Naaawwwzzzzz
awesome!
post pics of the process igor
Old Jan 9, 2004 | 07:43 PM
redstradic's Avatar
there are three little pieces that stick out and act as bracket. no need to glue or anything else.
