Grill Removal -- 2002
Old Jan 9, 2004 | 03:46 PM
2002 Maxima SE's Avatar
Does the front grill (with the emblem) come off the car? If so how? I'm trying to install two new horns and can't maneuver my hand to put it back on.
Old Jan 9, 2004 | 03:56 PM
maximilion's Avatar
I know this has been discussed many times before and I think all there is is three bolts/clip on the top that hold it in. remove those and then pop it out because there are some clips on the bottom and just pop out.
Old Jan 9, 2004 | 04:00 PM
Triple8Sol's Avatar
I miss the .org!
I took mine off to install Hella horns. I remember there being 3 screws you had to remove...
Old Jan 9, 2004 | 04:05 PM
Found the three screws. The one in the middle behind the latch looks like a tight fit. Will a normal socket wrench fit?
Old Jan 9, 2004 | 05:22 PM
Anyone? I really got to get this done!!!
Old Jan 9, 2004 | 05:56 PM
Playero's Avatar
Sanduguero
bro i told you just give it a janck and it will come off ....
Old Jan 9, 2004 | 06:01 PM
not the light. I have 2 of the three nuts off the grill. The last is right in front of the latch for the hood. I can't get my socket wrench back in there...its too tight.
Old Jan 9, 2004 | 06:07 PM
maximilion's Avatar
cresent wrench, monkey wrench, etc.
Old Jan 9, 2004 | 07:58 PM
Yeah, I finally found one small enough to fit in the space. There are two plastic partitions on either side and you can only move the wrench 1/2 inch at a time before you hit one of the partitions. To make matters worse, this third nut turns the opposite way of the other two. After installing the horns...I didn't bother putting that little nut back. What a pain in the @22. Pics and wav files to come.
Old Jan 9, 2004 | 08:08 PM
Stock Horn
Highway Blaster Horn
Old Jan 9, 2004 | 08:21 PM
1BADMAX's Avatar
Wow, that's alot louder than the stock horn. It'll defiently get somebody's attention.
Old Jan 9, 2004 | 08:25 PM
Yeah! I took the recordings at the same place...standing by the front driverside door. I'm real pleased with how this came out. The stock horns used to be almost as loud inside the car as outside. These new horns are more muted inside.
Old Jan 9, 2004 | 09:30 PM
6SPD_HLSD's Avatar
How is the bottom of the grill held on? Did you just have to pull on it to get it out after you removed the three top nuts?
Old Jan 10, 2004 | 07:15 AM
There are two clips at the bottom corners. You can see them sticking out if you look down with a flashlight. Put your finger under one of the clips and wedge it so you are pushing up with your finger on the clip, then pull on that side of the grill, you will hear it unclick. Now, have someone hold that side and do the same to the other. If someone does not hold it, the side will lock back in while you pull on the opposite side.
Old Jan 10, 2004 | 07:19 AM
MannyNJ2k2max's Avatar
cool.....very usefull...will get my Z horns sometime this week...
Old Jan 12, 2004 | 10:10 AM
For anyone who missed my weekend adventure...and may have questions on removing this lovely piece.
REDinLV
Aug 15, 2024 12:30 AM
RealityCheck
Oct 2, 2015 06:34 PM
09maxshawn11
Sep 30, 2015 10:28 AM
jaydot901
Sep 29, 2015 01:18 PM
