20mm spacers in front
This depends on the offset of your wheels, but most likely it will cause some rubbing. This isn't a huge issue up front, but in the rear, the tire will rub on the metal fender lip. I had this problem a while back due to spacers. It really messed up my tires in back.
Originally Posted by HKMax
My offset is 47mm and the width is 7.5"
I was asking more for the stress level that this will cause if any. I am thinking this won't since H&R spacers are hub centric. But then I never know.
Originally Posted by max'n out
Yes your asking for trouble, go buy a wheel that fits
Maybe someone with cash lying around maybe. But I am not that person. I want to work with what I have.If you think I am asking for trouble please elaborate why. I am having trouble seeing the problem here since H&R ones are hubcentric.
You have 47mm offset rims. You are planning on using 25mm spapers. I think your new offset will be 22mm which is way to extreme. You wan to stay between 35 - lower 40s offset. So to answer your question, will not work
Hmm, my question wasn't whether the spacers will work or not. I am pretty sure they will since I did some measurement. With this set up I should still have about 5mm to spare. My question was whether if these will create more adverse stress in any way.
Hubcentric means that the wheels or spacers or whatever are centered on the hub. When you buy a set of rims they usually come with hubcentric rings, aka hub rings, so you can center your wheels to the hub when yoou mount.
Originally Posted by Ammi
You might double check your calculations because I did not get 18" Volk w/ 30mm offset because they wouldn't work. I had to roll my fenders.
Hdnseek
Sep 9, 2015 05:55 AM
