sway bars
Old Jan 14, 2004 | 07:08 AM
takkar's Avatar
sway bars
I have a 2001 Maxima SE and i just found out that my front sway bars are loose and would require replacement ( they were making weird metal on metal noises on very low speed turns)...I've started to hear some similar noises from the back wheels too...So the question is...do we have rear sway bars too?
Old Jan 14, 2004 | 07:44 AM
soundmike's Avatar
Very sound, Mike
IIRC, yes. It's tucked inside the rear beam.
Old Jan 15, 2004 | 04:18 AM
wdave's Avatar
Yes, but the rear is welded in, no bushings or links to make noise. BTW, it must be the bushings or links that need replacing on the front swaybar, they're the only wear parts.
Old Jan 15, 2004 | 07:49 AM
takkar's Avatar
They didnt give me too many details..will ask them when I go in tomorrow...they did say it had worn out and was loose
Old Jan 16, 2004 | 02:05 PM
irish44j's Avatar
retired moderator
Just out of curiosity, on a related subject, is there a stiffer aftermarket front sway bar available to replace the OEM one?
Old Jan 17, 2004 | 04:50 AM
wdave's Avatar
Haven't heard of one, probably no one makes one because it would make the car handle worse unless you had a HUGE one to add to the rear and it looks to me like you'd about have to remove the engine to replace the front bar iself.
gman214
Sep 25, 2015 03:03 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
ColdCananda
Sep 20, 2015 10:45 PM
