Trouble shooting P0172
Old Jan 14, 2004 | 01:58 PM
CRIS_Y2K_SE's Avatar
this is what auto zone gave me " The PCM has determined that during testing, the fuel system for back one was too rich, (Bank 1 indentifies the location on cylinder #1, while Bank 2 identifies the cylinders on opposite bank) the guy at autozone told me that it is an oxygen sensor. what do i need to fix this , please help, thanx in advance.
Old Jan 14, 2004 | 02:37 PM
DanL's Avatar
There are two front sensors (one for each bank) and the ECU uses them to help maintain the correct air/fuel mixture, so yes, it would make sense that the one on bank 1 may be going bad. If you look at the front of your engine you'll see a line of multicolored connectors (3 or 4 depending on whether your car is Fed or Cali emissions spec). I believe the one with the black connector is the bank 1 sensor.
You can replace it yourself but they're usuall very hard to get out, even with an O2 sensor removal tool ($10 at you local parts store). Like all exhaust-related components they have a tendancy to weld themself in place and I seem to remember that one being really hard to get to as well.
Old Jan 14, 2004 | 04:27 PM
ok can you tell me about how much a sensor cost and are you refering that it costs $10 for the tool to remove the sensor. thanx again.
Old Jan 14, 2004 | 04:40 PM
DanL's Avatar
I seem to remember hearing that the sensor is around $120-$130 from the dealer and yes, the O2 socket tool runs between $10 and $15.
BkGreen97
Apr 2, 2016 05:47 AM
zmcneely13
Sep 26, 2015 02:26 PM
msellas
Sep 23, 2015 09:16 PM
jerrod99_se-l
Sep 15, 2015 08:55 PM
