Climate Control Lighting
Old Jan 16, 2004 | 05:01 PM
Cameron's Avatar
Anyone have any good instructions on how to remove the climate control unit on a 2K. The lights that illuminate the buttons have gone out and I am going to attempt to replace them.
I found some info on the removing the radio. Is the procedure the same?
I think I read that replacing these light bulbs are tricky. Any info on specifically replacing these bulbs?
Thanks.
Old Jan 16, 2004 | 05:58 PM
MaximaPolak's Avatar
Thanks.
Yes for the procedure.
THe Bulbs are not hard to replace.
Old Jan 16, 2004 | 06:19 PM
SterlingMist00's Avatar
I had the "procedure" done just 2 days ago by Jeff of MaximumTuning.net. You have to remove everything you see in the photo and the climate control and radio... You need 3 bulbs part# 27545-1W600. I got them from Dave B of Southpoint Nissan.
Old Jan 16, 2004 | 07:30 PM
Cameron's Avatar
[QUOTE=SterlingMist00]I had the "procedure" done just 2 days ago by Jeff of MaximumTuning.net. You have to remove everything you see in the photo and the climate control and radio... You need 3 bulbs part# 27545-1W600. I got them from Dave B of Southpoint Nissan.
Thanks for the info.
Do you know what kind of dissassembly of the actual climate control unit I will have to perform to get to the bulbs?
Old Jan 16, 2004 | 10:37 PM
Once you pull out the unit from the dashboard, I believe that you just have to remove 4 small screws from the back of the unit to expose the circuit board where the 3 small blue bulbs are screwed in.........
Old Jan 17, 2004 | 08:34 AM
tkostiuk4's Avatar
where is the whole procedure listed, I have the same problem!
Old Jan 17, 2004 | 08:39 AM
Same on the 2k3
I took it Apart 3 days ago, just to see if i can put
LEDs in the radio and climate controls.
Old Feb 14, 2004 | 09:17 PM
ICULookN's Avatar
Originally Posted by MaximaPolak
Same on the 2k3
I checked out your website, did you succeed at the process? What led's do you have in your window switches?
MikesChevelle
Mar 2, 2021 11:32 AM
dr3am
25
Oct 22, 2015 08:53 PM
asianstyle
Aug 24, 2015 08:29 PM
