Cattman/Progress RSB, need pics or links..
Old Jan 19, 2004 | 11:03 AM
GMoney's Avatar
I was in the middle of installing the RSB but noticed that the threads on the U-bolt that goes over the axle seems a bit too short. Did anyone else have this problem? I screwed the lock nut in as far as possible but it was about 1/3 of an inch from the axle beam.
I need some pics or a link to show me the exact placement of the U-bolt, not sure how far I should place it over the axle. I know there is a lot of pics and links of the Stillen bar but I need some for the Cattman bar..can anyone help?
thanks!
Old Jan 19, 2004 | 11:40 AM
MacAlert's Avatar
Did you put the metal plate on before you tightened then lock nuts?
Old Jan 19, 2004 | 11:52 AM
GMoney's Avatar
yes I did...I am thinking maybe I didn't push the u-bolt far apart enough, but even that wouldn't have gained me much...
Old Jan 19, 2004 | 02:31 PM
MaximaDisciple's Avatar
There should be more than enough thread to put the nut on unless they sent you a shortened u-bolt.
Old Jan 19, 2004 | 05:04 PM
GMoney's Avatar
Yup, I think they did send me the wrong part. See in your picture how the nut goes all the way to the bracket...when I turn the nut all the way up, I run out of thread and can't get the u-bolt tight...I guess I will just run to the parts store and get a different u-bolt...
THANKS!!
Old Jan 19, 2004 | 05:45 PM
IgS's Avatar
IgS
THANKS!!
make sure u get a real heavy duty one because if u get some flimsy one, your bar will come off pretty quick
Old Jan 20, 2004 | 06:04 AM
NYC TAR's Avatar
they sold you a 99-95 bar, their rear axis bean is more smaller. but the bar should be the same size.
Old Jan 20, 2004 | 05:55 PM
sweeper's Avatar
THANKS!!
I just got mine in the mail today for my 02. The u bolts measure just under 4.5 inches tall, with about 1.25 inches of thread at each end. Is that the same for yours? I tried to fit mine on there without acutully usign the nuts, and it looks like it's perfect. The threads go all the way up to where the washer will sit on the backer plate (but they don't go further than that!). Not sure if that will change once I torque it down, but,If they do, I'll just add some washers. If I were you I'd try the washer approach before the new U Bolt......never know how crappy a U bolt from HD or Lowes might be for that kind of G force.
Old Jan 20, 2004 | 06:42 PM
GMoney's Avatar
Don't have the u-bolts in my hands now but I will measure it up and see if it matches yours (prob. do it tomorrow evening). Thanks for the washer tip, I was also thinking of metal bushings that they have at hardware stores as an alternative...guess its the same concept as stacking washers...
Old Jan 20, 2004 | 06:59 PM
02VQ35's Avatar
The RSB will fit a 95-2003. Make sure the U-Bolt is pushed all the way down. When I installed mine, i had to tap it down with a hammer to seat it. Chris
Old Jan 21, 2004 | 06:26 PM
GMoney's Avatar
I just measured mines...it is the same measurement as yours. When I was trying to install it, I turned one of the nuts all the way up to the end of the thread and had about 1/3 of an inch play left; this was with the backplate and bushing...I would advise you to buy some washers and have it on hand just incase you are in the same situation as I was in. Not sure when I will have time to try again..too cold out these days (~20 degrees).
Or another problem may have been ME...I always doubt myself when working on cars, guess I am a little paranoid...
Old Jan 21, 2004 | 07:03 PM
SgtSchulze's Avatar
Burn Dust. Eat my rubber.
Kinda OT but I always wondered if there was a problem with servicing the car after the RSB is installed?? Anyone have a problem??
Old Jan 21, 2004 | 08:16 PM
SEdge
do you guys recommend using locktite for this install?
Old Jan 21, 2004 | 08:20 PM
bsetiawan's Avatar
Do put some anti seize compound and torque the bolts down properly and you should be fine.
Old Jan 21, 2004 | 08:34 PM
sweeper's Avatar
Yeah, give it another shot. There's only one Progress bar sold for maxima's by SWA, and since you have the same u bolts as me, you may have had the ubolt mis-aligned. the rear beam is not flat, it sits at an angle. You could have had the u bolt flat (meaning totally straight up and down versus angled the same as the beam), which would make one of the parts of the u bolt have more length. I held on my u bolt, back plate, and bushing by hand and made sure to pull both ends of the u bolt to the same length.
However, I will keep my washers handy though. they sure helped me on my ebay front strut bar!
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
BobTX10
Oct 7, 2015 08:43 AM
bigfrank
Oct 1, 2015 12:51 PM
