HLSD Differential Swap
Old Jan 21, 2004 | 01:43 PM
havenb's Avatar
I am looking to find any information on doing a differential swap to convert my max to the helical limited slip.
Does anyone have any information on where to buy one?
Also, any idea as to how hard / expensive a job it is to swap?
Lastly, what other modifications, if any, are worth doing while everything is apart for the differential swap?
Thanks a lot for any help.
Old Jan 21, 2004 | 01:53 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Most likely if it's similar to the non-LSD vs. LSD 2K-2K1s, you'll need at least the HLSD drivers' side axle. I'd bet it isn't possible to just swap the open diff for the HLSD.
You could always try the PhantomGrip.
Old Jan 21, 2004 | 02:49 PM
92 SE-R 02 SE
POLO was looking into this..i believe the tranny case is different, so your best bet is to find a wrecked o2-03 and get the tranny from that car. As for phantom grip, im not sure if they make one. If they do, its a great bang for the buck mod!
Old Jan 21, 2004 | 03:58 PM
studman's Avatar
I've already researched it. It's around $2000 at DaveB's price. The axles are the same for both LSD and non-LSD. All you need is the tranny and the tranny case.
Installation would be between 4-6 hours.
No upgraded flywheels or clutches are available as of yet.
Old Jan 21, 2004 | 04:43 PM
chinaonnitrous1's Avatar
perfect time to send out your new flywheel & clutch to have it upgraded
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
ef9
Oct 4, 2015 08:43 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Pied
Sep 26, 2015 03:29 PM
