first of all is this covered by warranty??
if not, where should i go and get another fuse??? the one on there look funky and irregular( so i dont think a regular auto parts store would have it)
this is on a 2k2 MAx
you have a 2002... everything is covered under warranty.
or if you want to do it, they'll have a replacement at autozone or pep boys...
Take your beautiful Tungten Blue Max back to the dealer and have them fix it under warranty. It could be something wrong in the wiring.Originally Posted by jeepik
first of all is this covered by warranty??if not, where should i go and get another fuse??? the one on there look funky and irregular( so i dont think a regular auto parts store would have it)
I blew one a couple weeks ago when I was installing my driving lights. Just tossed in a new fuse, and corrected my problem. Try putting in a new fuse yourself, they're 15 amp ones, and if it blows again, take it to the dealer
open the fuse box and look on the right hand side. The will be 3 spare fuses. (look on the cover of the box it will show you the spares. Just remove the correct size/color and replace the blown one. If it blows again take it to nissan it may be a short circuit.
sorry i guess i didnt make it clear....itr is actually a fuse RELAY...dealer will replace it under warranty, i just have to take it in
Quote:
A relay is a separate part of a fused circuit. Circuits that require a large current draw such as lights, horns and starters, require the use of a relay. It's always a good idea to let the dealer spend their dime instead of yours while your warranty is in effect.Originally Posted by jeepik
well its neither the realy nor the fuse...must be a short circuit somewhere..i'm taking it in tomorow morning to get checked out
