shock options
Old Jan 27, 2004 | 01:54 AM
NCBlue02's Avatar
shock options
I have an 02 SE 6 spd and I'd like adjustable shocks--I use the car for daily driving and autocross. KYB says they don't make an AGX for 02 and Koni Sports don't look like an option due to the nearly impossible to reach top of the rear shock tower. Any ideas?
Old Jan 27, 2004 | 03:43 AM
cobymoby's Avatar
KYB does makes a 4th gen AGX shock but you have to use the 4th gen top mount to get them to work. If you are looking for a serious setup I pulled my JIC FLT-A2's off the car a few weeks ago. Up for sale if you want them. The price is roughly the same
KYB's - ~$350
top mounts ~$150
springs ~$250
camber plates ~$400
Or take mine which are a full coilover setup for $1100 shipped.
Old Jan 27, 2004 | 11:50 AM
NCBlue02's Avatar
Thanks and I'd love your coilovers but that would bump me out of stock class in autocross. I have enough trouble keeping up with the Celicas now. Sounds like the AGXs with the 4th gen top mounts is the way to go. Are these mounts also needed with Tokico Illuminatis?
What'd you replace your JIC setup with?
Old Jan 27, 2004 | 02:11 PM
cobymoby's Avatar
Replaced with factory setup. Kept the sways and strut braces on though. I've heard that some people grind down the top mount that's on there now but I'm unsure. Cattmann.com sells the pre-modified AGX's.
Old Jan 27, 2004 | 02:44 PM
2k1IceMax's Avatar
No modification needed with the Illuminas. I've got them on my 01 SE. Look a little further down the board. There has been a lot of discussion the past few days about the Illuminas.
Old Jan 27, 2004 | 10:30 PM
NCBlue02's Avatar
How easy are the Illuminas to adjust? That's what I like about the AGXs--easy to adjust.
Old Jan 28, 2004 | 04:00 AM
ryand.white's Avatar
You adjust the Illuminas right on the top of the strut. very simple.
Old Jan 28, 2004 | 07:03 PM
NCBlue02's Avatar
Is that the same for the rear struts? Looks like it would be almost impossible to adjust from the top, given the metal crossmembers at the top corners of the trunk. AGXs have dials on the outside so you don't even have to pop the hood or use a screwdriver.
Old Jan 28, 2004 | 09:59 PM
speedy2k1's Avatar
The AGXs have dials on the rear set. The front you have to pop the hood and adjust. I have them on my AE with teins and love them. I had to drill the hole one size bigger on the stock strut mounts, but it wasnt a big deal. I didnt want to pay $45 a piece for the 4th gen mounts.
Old Jan 28, 2004 | 10:08 PM
NCBlue02's Avatar
Hey, thanks! That just saved me a wad of money.
Old Jan 28, 2004 | 10:09 PM
2kGLE's Avatar
No, the metal crossmeber isnt a problem. The illuminas are verry simple to adjust. Takes about a minute or two. There are pics of my drop with illuminas and eibachs in this thread. https://maxima.org/forums/off-topic/280224-0-interest-balance-transfers-life.html And there are pics of the adjuster screws in front and back on the second page. I use a flathead screwdriver bit with tape wraped around it to change the settings.
Old Jan 28, 2004 | 10:39 PM
NCBlue02's Avatar
Originally Posted by 2kGLE
No, the metal crossmeber isnt a problem. The illuminas are verry simple to adjust. Takes about a minute or two. There are pics of my drop with illuminas and eibachs in this thread. https://maxima.org/forums/showthread.php?t=280224 And there are pics of the adjuster screws in front and back on the second page. I use a flathead screwdriver bit with tape wraped around it to change the settings.
Doesn't look too difficult, not as bad as I had feared. Now I just need to find a good deal on either. Thanks!
Old Jan 29, 2004 | 12:10 AM
2kGLE's Avatar
EBAY $439 shipped.
Old Jan 29, 2004 | 12:23 AM
Triple8Sol's Avatar
I miss the .org!
Just remember, if you use 4th gen AGX's and modify them, you will need to use 4th gen springs!
Apr 16, 2020 05:15 AM
Stagnet04
Oct 11, 2015 08:16 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
Redfox
Sep 28, 2015 10:41 AM
