Drop Resistor Mod
Old Jan 27, 2004 | 09:27 PM
KiKinMax11's Avatar
Drop Resistor Mod
I've been looking at max's all over and a lot seem to have this drop resistor mod. I was curious to what it is/does. Can someone respond who knows what tehya re talking about, or IM me at italiano punk 03! thnx
2000 Maxima SE
-Weapon-R intake
-Custom Straightpipes
-Custom Maxima FSTB
-ECU Mod
-NISMO lowering springs
Old Jan 27, 2004 | 09:30 PM
gsu_y2kmax's Avatar
ECU Mod for a 2000? Nismo lowering springs?
Old Jan 27, 2004 | 09:31 PM
KiLLeR2002se's Avatar
Eat Naaawwwzzzzz
it pretty much removes a sensor that controls the pressure line for the tranny. when your at wot, the line is at full pressure, so quick powerful shifts are needed. when you're not in wot, obviously you dont need it.
when you remove it, you maximize the lines pressure causing the tranny to shift gears vigorously. please think its "cool" and "faster", but they are seriously screwing up their trannys. the ear forces itself in and sometimes they experience a loud bang and feel it too...
i dont recommend it at all
Old Jan 27, 2004 | 09:38 PM
KiKinMax11's Avatar
I have the ECU modulator in my car to control the air/fuel ratio, and spark timing! I also have knock off NISMO lowering springs, they are for a 2000 maxima but looka nd ride like my friends 95 maxima so inturn are NISMO knockoffs!
Old Jan 27, 2004 | 09:39 PM
Eat Naaawwwzzzzz
knockoff nismo springs? never seen em.... care to post some pics?
Old Jan 27, 2004 | 09:45 PM
KiKinMax11's Avatar
They are on the car as we speak, so I can't show you the springs ora picture, but I can post a picture of my car and its final touch! its a 2.0 inch lowering all around and the springs are blue!
Old Jan 27, 2004 | 09:47 PM
Eat Naaawwwzzzzz
ya thats what im talking about...a pic of the ride...
show some pics!
Old Jan 27, 2004 | 09:51 PM
KiKinMax11's Avatar
hows soon sound cause where i am its snowing serioulsy like 5 inches...so when its clear ill get some shots n post or if u send ur email ill send em there...what you running in your car?
Old Jan 27, 2004 | 09:53 PM
Eat Naaawwwzzzzz
ya dude, post em here when u get them, im sure everyone would like to see em...
I got 4th gen H&RS/KYB AGX. i want my front a little lower, im contemplating on just teins in the front. Im a little shakey becuase Im gonna install my lip soon
Old Jan 27, 2004 | 09:57 PM
KiKinMax11's Avatar
If your getting a lip dont lower your car, my car bottoms out everywhere although its hot riding low, better turns and road hugging is the immediate response! and it rides liek **** over bumps, i have the tokico struts for my car and its like off road!
Old Jan 27, 2004 | 09:58 PM
Eat Naaawwwzzzzz
oh, ya i dont want that. The h&rs are really soft.. I know how to drive a lowered car, ive never scraped before, even in my older car, i had a kit and way lower...rarely scraped
Old Jan 28, 2004 | 07:42 AM
Jime's Avatar
Killer you are close but not quite right.
The resistor does control the line pressure for the trans. However when you are at WOT the trans is NOT at full line pressure, it is never at full line pressure it is always at some fraction of it. Full line pressure is just the maximum the pump produces.
This mod should only be used with a WOT switch or manual switch when you are at WOT only. It is NOT to be used at part throttle.
It will not screw up your transmission if it is working properly in the first place and you use as I indicated above. (get at trans cooler also)
I have used this mod on two Maximas now for 2 racing seasons and it works flawlessly. It will actually save wear on your transmission because it makes the transmission shift faster at WOT thereby reducing wear on the clutches.
People who have screwed their transmissions using this mod, either use it at part throttle or already had problems with their transmissions. Also some people can screw up their transmission N/A and I have used this mod to make several 12 sec runs which is considerably harder on the powertrain.
However any mod you do to your car to make it faster/quicker could and can reduce the life of your car so if it breaks don't blame me. This is just my experience. However that is probably better than listening to someone who has never tried it but is an expert.
Old Jan 28, 2004 | 07:52 AM
Eat Naaawwwzzzzz
Hey jim, ya thats what I meant, it can screw up your tranny under partial throttle. Thats what a lot of people were doing and crying that it slammed into gear and "is it bad"...
Old Jan 28, 2004 | 08:00 AM
2001SE's Avatar
I saw a while back a thread about installing a device to make the tranny go into full pressure when you WOT. What do I need to buy to make this happen?
jonreidhead
Jan 6, 2016 09:38 AM
knight_yyz
Nov 1, 2015 01:34 PM
maxima-junky
Oct 7, 2015 06:13 PM
Redfox
Sep 28, 2015 10:41 AM
