JTW POP CHARGER HELP!!! CHECK ENGINE SOON
Old Mar 7, 2001 | 05:55 PM
MAXIN24-7's Avatar
After installing the pop charger I noticed the check
engine soon light came on.
What could be the cause of that?
Followed directions..
Still outside looking for the prob.
Old Mar 7, 2001 | 05:59 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
Unplug your battery for a few hours to reset the ECU... hopefully you shouldn't see the light come on for a long time afterwards.
Old Mar 7, 2001 | 06:13 PM
y2kse's Avatar
What is it about cone intakes and 5th Gens?
Well hopefully resetting the ECU should take care of it. If not, return the JWT Popcharger, put your stock airbox back on, and install the OSCAI conversion instead. You won't be sorry.
Old Mar 7, 2001 | 06:17 PM
punkdork's Avatar
I never got the check engine light when I had my pop charger installed but I did get knocking and pinging!! Gotta love that. I'm OSCAI all day way now.
Old Mar 7, 2001 | 07:06 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
It's the MAF(Mass Airflow Sensor) guys, probably due to the increased air turbulance in the air flow. I've messed with one before and they are tempermental SOB's.
Hopefully, the disconnecting the battery works, but if not maybe their is another way to reset the ECU. I know the Sentra's had a screw on the side of the ECU after you uncovered it that could be used to check ECU codes and reset a check engine light.
Old Mar 7, 2001 | 08:07 PM
MAXIN24-7's Avatar
Unplugging my battery did the trick... BUT......
hopefully I won't see the light come
again for a while anyway.
Also, you know the piece from the old
air box with the 4 holes in which bolts
go through... (Cylinder) Do you think it will be
a problem if a corner or screw hole
cracked off when swapping it to the new cone.
I only have 3 bolts on the cone but the
hole were the air passes is sealed.
This day has been a mess
I also stripped the allen key bolt on
the Courtesy FSTB. Hopefully ATV will
have a replacement bolt. Dont want to
wait for Courtesy to send one.
Not sure how I am going to get it out though.
Old Mar 7, 2001 | 08:14 PM
kafene's Avatar
Re: Unplugging my battery did the trick... BUT......
i have the same problem. light went on after the y-pipe. then again after the stillen intake. the light will go off after you 'reset' it w/ the batter disconnect, but will probably go back on. if you leave the engine light on and assuming it's the same problem, it should turn off after about 40 key cycles (for the max). of course, this does not necessarily mean the problem went away; it just means that the car assumes you don't want to take care of it, or it means that the sensor went dead (which in most cases is rare).
kafene.
Old Mar 7, 2001 | 08:55 PM
punkdork's Avatar
I did the same thing on the intake.. snapped one of the bolts. I ran 10k with my pop like that.. I had knocking and pinging which I'm sure was related to the pop charger itself not the missing bolt. You should be fine.
Old Mar 7, 2001 | 09:27 PM
MAXIN24-7's Avatar
Thanks Alot to all
Thank you all for your help on this mods.
I will keep you all up to date after ATV tomorrow.
Keep your fingers crossed......
Dont want to wait.
MAXSE5SPD
Sep 17, 2022 04:00 AM
CorollaULEV
30
Aug 9, 2021 08:11 PM
cruce91
Sep 20, 2015 10:23 AM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
