Autometer guage install questions
Old Jan 29, 2004 | 10:31 AM
2k1maxgle's Avatar
I just recieved my autometer guages and the guage pod should be here 2morrow, i was wondering if anyone can post a quick how to for installing the fuel pressure guage and the a/f guage. Where do i run the sender for the fuel pressure guage, and how do i hook up the a/f guage. Nitrous pressure guage isnt a problem, i just have to get the 20' sender harness because my bottle will be in the trunk, or can i just extend the wires myself?? anyway...i need some help with the install of the fuel pressure guage and the a/f guage. Could someone post pics of where you ran wires through and where you have your senders hooked up.
Old Jan 29, 2004 | 11:13 PM
KiLLeR2002se's Avatar
Eat Naaawwwzzzzz
the nitrous sender should be mounted in the engine bay not on the bottle... the fuel pres. sender should be mounted where you need to tap into the fuel line. I dont know what kit you are using but on a wet kit you have to cut into the line. form a tee there and put your sender there. this hose is 200 at the dealer, so u know what you're dealing with.
i got it for about 50-60 from a junkyard.
the a/f guage should be tapped into a wire from your 02 sensors. pick on closest to the ecu and tap one by one until u get the correct one, or maybe someone knows which wire it is.
i would however recommend a apexi or greddy EGT over the a/f ANY DAY of the year.
PH98I30
Jan 9, 2025 08:08 AM
Cotozic
Jun 28, 2017 08:01 PM
95Maxi
Aug 25, 2015 08:01 PM
mikekay
Aug 10, 2015 12:52 PM
