SMELLS LIKE SOMETHINGS BURNING>>>>HELP
Old Feb 1, 2004 | 04:46 PM
greekmax2k1's Avatar
ok my freind did a fog light rewire...it was working good the first day....the second day the left light stopped working and now wen i turn the foglights switch on it smells like some wire is really burning any ideas of wat it is....has this happened to anyone alse...
Old Feb 1, 2004 | 04:49 PM
limsandy's Avatar
Could be the fuse being fried...... Did you wire them correctly? Did you forget to wrap the bare wire with lots of tape?
~limsandy
Old Feb 1, 2004 | 05:21 PM
would the fuse keep getting freid though or it just blow the first time and thats it...cause it smeels everytime i turn them on....and i m not usre he tapped it cause i didnt do it...
Old Feb 1, 2004 | 08:21 PM
† ErV †
no, fuses blow and that's it. could be a loose connection that makes a little short and hence you get the smell, or could be improper wiring. just go visually over all the wires.
Old Feb 12, 2004 | 11:50 AM
Teufelhunden's Avatar
maybe the water got in the connection?
my fog wires got fried, because the electrical tape was loose and water got into it, so i just rewired it.
Old Feb 12, 2004 | 11:59 AM
Nathan's Avatar
Same thing happen to me last week. Melting right threw the wire loom too.
Old Feb 12, 2004 | 12:17 PM
krazyd's Avatar
nissan uses real low-guaged wiring for all of our electrical components, especially lighting. double-check all your wiring and make sure everything is still intact. you should not be smelling any burning inside of the cabin. if anything, the burning smell should only be in your engine compartment, near the fusebox.
Old Feb 12, 2004 | 06:24 PM
MaximaPolak's Avatar
Maybe I should do this for you? never let a Greek do a Polak's Job.
I think you need a thicker wire. I think I used 12 or 10 guage.
tarun900
19
Dec 20, 2021 06:57 PM
leatherneck
Sep 30, 2015 09:16 PM
dshinn
Sep 26, 2015 08:07 PM
