rear sway bar
Old Feb 1, 2004 | 06:53 PM
s_hinerman's Avatar
rear sway bar
I know this has been asked a thousand time but since search is not working I was wondering which rear sway bar is the best for the money.
I know that some of them have brackets that you have to move the brake lines and such. Please any help is much appreciated.
Old Feb 1, 2004 | 07:07 PM
Slow Moe's Avatar
From what I seen all the sway bars are the same. I Have the stillen one but if I were you i'd look at the progress since they are all the same from what I heard.
Old Feb 1, 2004 | 07:25 PM
KCMichaelM's Avatar
You'll pay more for Stillen but I love mine... It has the necessary hardware to go around brake lines, etc... Also I have heard people complain about having to be careful around speedbumps on other brands, and I drive over at least 10-15 speedbumps throughout the day and I have never scraped once, and I don't baby it by going slow over them either! I've had mine over 80k miles so far, it works great!
Old Feb 1, 2004 | 08:15 PM
crispykid717's Avatar
Bigger than Jesus
I should have my progress rsb on by next weekend and will post my opinions and results soon after i install it.
Old Feb 1, 2004 | 08:16 PM
Triple8Sol's Avatar
I miss the .org!
Best bang for the buck: Progress...period...
Old Feb 1, 2004 | 09:21 PM
KCMichaelM's Avatar
It wasn't out when I got mine.. I hear it's similar to Stillen; if it is, by all means I'd go Progress too.
Old Feb 1, 2004 | 09:24 PM
maxiiiboy's Avatar
I have Stillen's, but next time around I would get one of the less expensive ones. I don't think there is much difference in performance and you can save some money.
The RSB has tremendous impact - it just levels the car. You'll love the feeling - the car just sling-shots out of curves. On the other hand, there is a more pronounced axle hop on bumpy roads.
The net result: Unless you drive on bumpy roads a lot (gravel, etc.), you can't go wrong. If you do drive on gravle or poor asphalt ("roulette"), I would do some testing before making the decision.
Good luck !
Old Feb 1, 2004 | 09:59 PM
Maximam's Avatar
If you are lowered and don't want your rear brake lines ground open get a Stillen bar.
Old Feb 2, 2004 | 01:50 AM
HNDA ETR's Avatar
Still Here... IM me for more..
I'm no fan of $teallin... but my $teallin rear sway bar is a pretty quality piece...
I think it's better than the sway bars that use the "U" bolts...
Old Feb 2, 2004 | 04:23 AM
SoonerFan's Avatar
Cletus
i just put the progress on this weekend and LOVE it!!
Old Feb 2, 2004 | 09:24 AM
s_hinerman's Avatar
Thanks for all the help
If anybody else has pro or cons of any let me know
Thanks Again
Old Feb 2, 2004 | 10:27 AM
sweeper's Avatar
Ive had the Progress bar in place for about 2 weeks and it made a big diff in handling. From the research I gathered prior to purchasing, here's why I figure:
Progress Bar: Cheapest, but not the easiest to adjust from to "stiffer". (install write up: http://forums.maxima.org/showthread.php?threadid=189641)
Addco: a bit more $ than Progress, same design, but side brackets "look" easier to adjust. (link to addco install: http://audtatious.win.net/audio/tech/addcorsb.html)
Ebay-Stillen Knockoff: cheaper than a real stillen, but still cost more than Addco and Progess. Appears to be identical to the real thing, other than the name.
Stillen: most expensive, thickest, but probably the easiest to install and adjust due to thier brackets. (install instuctions: http://www.paulwendy.com/maxima/rsb.htm)
I'm very happy with my Progress bar for the money, but to adjust it to stiffer mode, I'll have to fiddle with it a bit more. Not a problem for me, but could be for someone else.
Old Feb 2, 2004 | 10:51 AM
s_hinerman's Avatar
Thanks for all the info. Looks like i have some homework to do.
Old Feb 2, 2004 | 03:22 PM
s_hinerman's Avatar
does anybody have the stillen knock off bar?
How does it work, fit?
lowpost99
Oct 26, 2025 06:53 PM
matts95max
Apr 23, 2025 10:44 AM
bbsitum
Sep 11, 2015 04:55 PM
flu2000
Sep 8, 2015 02:23 PM
