for those with cf hood
Old Feb 3, 2004 | 01:58 PM
gramenis's Avatar
For those of you with carbon fiber hoods....
Are the hood shocks utilized?
How do you remove the windshield squirters?
Any special cleaning required?
Old Feb 3, 2004 | 04:19 PM
Larrio's Avatar
The Definitive AE Master
usually the CF hoods are not pre drilled for hood shocks. Also considering the fact that the CF hood weighs considerably less than the stock hood, the stock shocks would shoot the CF hood up too fast.
the windshield squirters can be removed by just pulling out the lines. I've seen members that just plugged them up also.
no special cleaning required. But it sure looks nice when you wax it
Old Feb 3, 2004 | 04:20 PM
Ferbs02SMMax's Avatar
You may wanna PM Mike Jez (i.e. BlackbirdVQ), he can give you an answer. I don't think he comes into the 5th gen forum much anymore, but he answers PM's. He's always busy building up some insane creation.
Old Feb 3, 2004 | 05:09 PM
Deac's Avatar
CF Hood
The VIS hood (like mine) already has washer nozzle holes pre-drilled. It does not require special cleaning but I like to you windex on mine... the clear coat finish stands out more that way.
Hood shocks cannot be used when you get a CF hood.... not sure why but you cant use them. Check my site for pics.
Deac
Old Feb 3, 2004 | 05:24 PM
BigDogJonx's Avatar
You cant use the Hood shocks cause it has too much force so when you go to shut the hood, you will crack the CF hood near where the hood shock is mounted.
Dixit
Old Feb 3, 2004 | 10:40 PM
JayMax2000's Avatar
How much lighter is the CF hood over the stock?
Old Feb 3, 2004 | 11:17 PM
myktek's Avatar
it's like 10+ lbs lighter....just unplug the cabling for the washer nozzles, and then squeeze the washer itself and it just comes right out...real easy....as far as the shocks, i've been wanting to make something that can support it....it's annoying as hell w/o them...
Old Feb 3, 2004 | 11:22 PM
Blk2kMAXSE's Avatar
ummmm, i have a VIS cf hood and i use the shocks. i've had it for about a year now with no problems.
Lam
Old Feb 4, 2004 | 04:35 AM
gramenis's Avatar
Thanks for the help.
I got done around 8pm last night. The VIS oem hood needed to have the stock hinge holes drilled a little, because the fit wasn't exact. I think I will hold off on the hood shocks and come up with an alternative.
Old Feb 4, 2004 | 06:18 AM
Woo Cho's Avatar
when I got mine I was afraid to drill hole for the hood shock mount cuz I heard that there's possibilities that surrounding the hood shock could form a crack and it can extand that's why I didn't get the hood shock on. I carry snap on tools hood stand in my trunk......
Old Feb 4, 2004 | 09:26 AM
myktek's Avatar
Lam
can u show us some pics of it? thx
Old Feb 4, 2004 | 03:10 PM
JayMax2000's Avatar
Wow, its only 10 lbs. lighter than stock I thought it would be at least 15 lbs. or so.
Old Feb 4, 2004 | 07:33 PM
myktek's Avatar
it's prob more then that, i wasn't sure, thats y i put 10+....hehehe... i think it's like 29lbs for stock and 12 for cf...but not sure...
Old Feb 4, 2004 | 08:52 PM
Woo Cho's Avatar
thas not true......even those CF hood hood weighs more than 15lbs
Miket2006
Mar 1, 2021 03:55 AM
AaronL
Aug 8, 2020 10:31 AM
howardis
Dec 11, 2019 06:10 PM
Unclejunebug
Apr 2, 2016 05:42 AM
leatherneck
Sep 30, 2015 09:16 PM
