Cattman Y-pipe just installed
Just had the Cattman SS Cali-spec Y-pipe installed at Jeff's (MaximumTuning.net). It looks great and the car feels like I don't have to dip into the throttle as much to attain the same acceleration as I would without the Y-pipe. The ECU will be reset to help it adapt faster to the better breathing.
Check out my page for more install pics.......... next is the Cattman Mid-pipe
Originally Posted by bsetiawan
Did you experience any banging during hard acceleration ? If not, did you lower the center brace underneath the car with washers ? The pipe looks cool though.
I understand that you can do it yourself... the negative battery terminal has to be disconnected for a period of time, I forget how long, and that resets the ECU.
But it can also be done by some code readers. Jeff at MaximumTuning.net reset my ECU (free of charge) after he installed my UDP.
Originally Posted by zoolyfe
what about advanced timing? what are the gains of this and how do i go about doing it?
You can view this thread Timing advance and look at the sub-thread in the 2nd post for more info....hope this helps.
Violator
Sep 9, 2015 10:14 AM
