installing clear front bumper lights...
Old Mar 9, 2001 | 03:17 PM
DooBall's Avatar
I'm not sure how to remove the front bumper lights...
in the manual it says to use a cloth and a screwdriver (or whatever), and "pry" it off,
but when i tried to, its real resistant, and im worried about bending/scratching my bumper.
do i just continue to pull or am i doing it wrong?
Old Mar 9, 2001 | 05:05 PM
The New CLIMAX's Avatar
From the back end of the marker, get your flat
head screw driver and place a cloth around the tip, then pry it off, it should be a little resistand, but not that much. If you are doing this then its right.
Old Mar 9, 2001 | 05:10 PM
y2kse's Avatar
The lens is spring loaded. The idea isn't so much to get behind the lens and dig it out as it is to push the lens toward the front in order to compress the spring. To do that, take the screwdriver wrapped in a t-shirt or towel and wiggle your way in behind the back of the lens. As the screwdriver works its way in, it will compress the spring. Eventually the spring will compress sufficiently for the lens to release from the rear.
vingodine
45
May 21, 2016 12:46 PM
JoshG
21
Sep 4, 2015 09:04 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
jomax14
Aug 12, 2015 11:49 AM
