Auto climate won't turn on!!!!!!!!
Old Feb 14, 2004 | 03:54 PM
Kevlo911's Avatar
Kevlo for President
My friend opened his autoclimate control in his 01GLE to see the bulb(one was out) and not it does not turn on
no lights or anything, no display. NO AIR.
what should he check and doo, he was extented warrenty also
Old Feb 15, 2004 | 06:32 AM
Kevlo911's Avatar
Kevlo for President
wtf, anyone?
Old Feb 15, 2004 | 06:50 AM
mdeal's Avatar
Perhaps the wiring harass has come loose. You can remove the top vent by pulling out, removing the ash tray/change holder, remove the shift surround, then find 4 screws at the top and bottom holding the stereo AND climate controls together. Reach behind from top or bottom and make sure the harness is in there good. I believe the thing has to be screwed back down (the 4 screws) before the radio or climate controls will work (<-- mine would not for some reason ).
Old Feb 15, 2004 | 06:53 AM
mdeal's Avatar
Also, I assume you have checked the fuse with a tester.
Old Feb 15, 2004 | 06:55 AM
Kevlo911's Avatar
Kevlo for President
i checked the fuse in the interior fuse panel that said "Air CON" any other fuses to check?, harness is in there nice and snug.
Old Feb 15, 2004 | 06:37 PM
mdeal's Avatar
Try to get it to "diagnostic mode" to see if that works. Don't worry, you won't screw anything up and you can leave this mode by simply turning off the car.
Do this:
(1) With car turned off, depress and hold "Off" button.
(2) Turn car on while STILL HOLDING the "Off" button.
(3) Continue holding button after starting car until a bunch of stuff appears on the screen, which should take 5 seconds.
If a bunch of unusual text appears in the climate control display, then you are in diagnostic mode. If you get this far, there is hope; otherwise, something more serious is probably wrong. At this point, you can change something, or just hit the "Auto" button again to leave this mode or turn off the car and that does it, too.
Let us know what happens or e-mail me and I can guide you through the diagnostic part (since it is multiple steps).
Old Feb 16, 2004 | 07:12 AM
Kevlo911's Avatar
Kevlo for President
i will try that today, but i don't think ti will work because the buttons don't tlight up anymore either. but i will give it a shot
boomerbrian
Oct 31, 2018 10:25 AM
bryants95max
Oct 2, 2015 12:52 PM
LtLeary
Sep 14, 2015 12:33 PM
