Changing Fog Lights
Old Mar 10, 2001 | 10:22 AM
Changing light bulbs in stock fog lights
Hello, I am new to this board and I would like to know where I could get information on changing the lights in my fog lights. I have seen that some of you have changed yours. Do I need to take the fog housing out?
Thank you very much!
[Edited by 2001MaxSE on 03-10-2001 at 02:41 PM]
Old Mar 10, 2001 | 12:42 PM
please...anybody have some info??
Old Mar 10, 2001 | 01:14 PM
The New CLIMAX's Avatar
This is from YJ I think ohh well here it is
oglights
H3
Time consuming if you don't know what
you're doing. Remove the front splash guards. Remove the screw holding the foglight assembly. Change the bulb just like the headlights.
This is from someone else that posted
Replacing 2K foglight bulbs
here's some help. Undo all the rivet thingies (black plastic stuff) from the outer edge of the car. Keep going until you get to the middle of the wheel. Next pull/push the black fender away so you can put your hand and see the fogs from the inside. Undo 1 screw and push. CATCH THE LAMP because it's going to fly out. Undo the bulb and follow the instructions in reverse to reinstall. Hopefully this helps! Good luck!
Old Mar 10, 2001 | 07:52 PM
nisMAXse's Avatar
Do a search for 'foglight bulb replacement' under this forum using the link in the upper right hand corner of the forum pages. There are past threads on this topic...
Old Mar 11, 2001 | 05:33 AM
yongjun's Avatar
message me on aim if you have any more questions
y2kse00 or yj4u2c
vingodine
45
May 21, 2016 12:46 PM
EuroDriver
Sep 14, 2015 06:08 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
98nismomax
Aug 13, 2015 12:44 PM
