Front drop not rear?
Old Feb 15, 2004 | 07:53 PM
irish44j's Avatar
retired moderator
Ok, I'm looking at the car today and thinking that I think the back wheels sit nicely into the wheel wells but there's much more gap in the front. I was thinking that it would be nice to be able to drop the front maybe 1/2 inch and leave the rear stock height, and that would level out the car nicely and not really look "lowered".
Any ideas? From what i can tell the least drop front springs out there right now are about 1.2" which is more than I want to go.....
I just want to keep the car looking more or less stock, not lowered, but just get rid of a little bit of the front wheel gap....
Old Feb 15, 2004 | 08:10 PM
zipper's Avatar
Just rebend the springs to get the height you want.
-Zipper
Old Feb 15, 2004 | 08:52 PM
ChromeSE5's Avatar
doing this will raise the angle of your car actually, making the rear view of ur car looking higher than stock; but i had chopped maxspeeds in front so that could have been the reason for such a dramatic look.
Old Feb 15, 2004 | 09:04 PM
housecor's Avatar
I know what you mean, the front gap is really unsightly. Eibach is the least severe drop, so you could use a front set. However, they are a far higher rate spring than stock and would require a strut replacement up front as well. The result might look fairly even, but ride and handling with mismatched front and back stock/stuts? I'd imagine iffy at best.
Old Feb 15, 2004 | 09:37 PM
limsandy's Avatar
If you're not changing rear springs, it's recommended that you pick a pair of front springs that has spring rate close to stock springs. I think, in this case, H&R is the closest?
~limsandy
Old Feb 15, 2004 | 10:10 PM
scopium
just buy maxspeed and put on the front springs
its about a 1.4 inch drop.. looks nice
Devo
18
Mar 7, 2016 07:36 PM
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
Greenmaxspeed
Aug 8, 2015 12:39 PM
laparka66
Aug 6, 2015 09:36 AM
