Headlight Socket Toasted ! Need Help
Old Feb 16, 2004 | 01:16 AM
Max2K's Avatar
My 2k Max headlight socket got toasted with the high wattage bulbs . I got some APC replacement sockets, does anyone have any idea or any diagrams so I can properly rewire them. Ive been mixing and matching and got it rewired to high beam only . The APC socket came with 3 wires black, blue, and white. I believe the original wires from the Max was orange, black, and green. Thanks.
Old Feb 16, 2004 | 02:27 AM
TZapper's Avatar
Sorry cant help with the wiring, but what bulbs did you use? The car manual and bulbs instructions clearly state not to use higher wattage than the maximum allowed.
Old Feb 16, 2004 | 03:29 AM
JdoubleOe703's Avatar
teddibear703
happend to me before, using the blue "hid like" bulbs... i dont remember how i redid my wiring, good luck though...
Old Feb 16, 2004 | 04:06 AM
Ammi's Avatar
350 Detroit Muscle
Probably used some cheap brand
Old Feb 16, 2004 | 11:47 AM
Max2K's Avatar
I was using APC. The brand has notihng to with it, its the wattage .
Old Feb 16, 2004 | 05:36 PM
Ammi's Avatar
350 Detroit Muscle
Brand name has ALOT to do w/ it. I've been using PIAAs (higher wattage) for over 3 years on my other cars. No problem. When I put no namer on my friends car, entire harness melted. Bulb costed half of PIAAs.
APC bulbs are crap anyways.
Old Feb 16, 2004 | 06:39 PM
2MuchMAX4U's Avatar
When I replaced my old harness, I removed the cover of the old harness on the back and matched the wires on the new harness. If your stock one is toasted maybe you can look at the other side and eye ball it. The harness is in a "T" shape you should be able to see which wire goes to which contact. Good luck compare the two harnesses and you'll be ok!
Old Feb 16, 2004 | 07:42 PM
MaxVader's Avatar
I just got some of those, If they cause problems like that they will be out tomorrow!!!!!! Funk That!!
Old Feb 16, 2004 | 08:19 PM
Max2K's Avatar
Once again it doesnt matter what BRAND . If your harness and socket cannot handle the recommended wattage the socket will melt eventually. I had my APC's for 4 years before it melted because it was 90/100, not because it was "crap" APC.
Old Feb 16, 2004 | 08:26 PM
asu174's Avatar
Clay Aiken has fancy genitals
I would order new stock harnesses from DaveB.
Old Feb 16, 2004 | 08:41 PM
Ammi's Avatar
350 Detroit Muscle
Your APC burned your harness. My PIAAs didn't
Old Feb 16, 2004 | 08:43 PM
asu174's Avatar
Ever play Russian roulette? That's what you're doing. It's only a matter of time.
Old Feb 16, 2004 | 08:59 PM
Ammi's Avatar
350 Detroit Muscle
Just trying to get a message across that brand name matters (higher wattage bulbs)
Old Feb 16, 2004 | 09:02 PM
mclee45's Avatar
High wattage bulbs will eventually melt your plugs. Doesnt matter what brand. Had mine for 4 years before it melted. I was running 110/130 watts too which is hella high. now i switched to real HIDs
Old Feb 16, 2004 | 09:19 PM
Ammi's Avatar
350 Detroit Muscle
I guess I'll have to wait and see if my PIAAs will burn out my harness.
Old Feb 16, 2004 | 09:25 PM
TZapper's Avatar
PIAAs arent higher wattage than stock.. they are all 60/55w
Old Feb 16, 2004 | 09:30 PM
Ammi's Avatar
350 Detroit Muscle
There are 80 and 85 Watt PIAA bulbs. I've been using 80
Old Feb 16, 2004 | 11:01 PM
thomasd cook's Avatar
What I did was use a meter and check to see on the other socket which is your low, high and ground. If you've got the socket the way the bulb sits in the housing, then the very right plug is the ground. Then the top plug is the low beam and the left is the high beam. Not sure of colors I've got it all taped up and can't see. Try a meter and test each wire. It took over a year and a half for mine to burn out. The light continously went on and off. When I looked at the harness it crumbled in my hand. Huge fire hazard, but it's taken care of now.
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
knight_yyz
Nov 1, 2015 01:34 PM
trsandrew
Oct 25, 2015 02:47 PM
Noela
Sep 26, 2015 08:22 AM
