safer side marker install
Not sure if i am the first one but:
I found a much safer(on the paint) way to install your side markers.
On the front if you take the 2 screws out of the under molding, like you were going to change a fog light, then just reach up and push out the front of the lense and that is it. The rear isn't quite as easy. Just pull the trunk liner aside and then there is a rubber water sealant plug that you just pull out, then if you use a flash light and a long flat head or other such pushing device. You can locate the the housing then use the pushing device or screwdriver to push it out.
Thats it
Thats it
I think using a small screwdriver with a towel wrapped around it is easier. Took me all of 10min to change all 4 corners. The way you suggest sounds like it will take atleast 30min to take out all four.
On the front if you take the 2 screws out of the under molding, like you were going to change a fog light, then just reach up and push out the front of the lense and that is it...
Backs are sloppy enough I dont have issues with screwdriver and towel. Fronts are wedged in super tight on mine.
Originally Posted by scopium
yea so next time if u wana change your turn signal bulbs or headligt bulbs just take out the whole headlight so u wont scratch the housign.. its safer !!
Thats it
Thats it
vingodine
45
May 21, 2016 12:46 PM
95Maxi
35
Sep 2, 2015 10:37 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
