Exhaust Wrap!
Old Feb 16, 2004 | 04:23 PM
Trance Artur's Avatar
Exhaust Wrap!
what's a good exhaust wrap size to use. 1'' or 2"
Old Feb 16, 2004 | 04:27 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
2" is much easier to wrap and keep a grip on so you can keep it tight. ive used both and 2" just makes it go quicker and easier.
Old Feb 16, 2004 | 06:11 PM
PearlWhtMaX2000's Avatar
does exhaust wrap really work well?
Old Feb 16, 2004 | 06:23 PM
bigdo26's Avatar
I've heard that wrapping the exhaust causes it to rust faster...
Old Feb 16, 2004 | 06:30 PM
sloppymax's Avatar
if you live in a real wet climate or a place where road salt is used a good bit then you might want to rethink it. i have had two different types of wrap on my y pipe for about a year with no rust. this is in charlotte, nc climate and with a stainless steel cattman y. i use it to quiet down the flex section. i am sure its good for reducing underhood temps but that was not an issue for me.
Old Feb 16, 2004 | 08:47 PM
VMaximus02's Avatar
If your have stainless steel exhausts, will wrapping the pipes cause rust later?
Old Feb 16, 2004 | 10:44 PM
SEmy2K2go's Avatar
Go BUCKS!!!
Thermotech makes a product that you apply to the wrap after installation which prevents fluids from penetrating the material.
Old Feb 17, 2004 | 12:09 AM
[maxi-overdose]'s Avatar
I use 2" on my ypipe....what do you try to wrap?
Exhaust wrap is good to keep a stable exhaust gas temp reading. Others have used it to wrap their exhuast manifold to reduce engine bay temp. no rust so far with my stillen ceramic coated pipe.
Old Feb 17, 2004 | 07:01 AM
VMaximus02's Avatar
I heard that it's not good to wrap the flex section on the y-pipe. It needs room to "flex" under high exhaust pressure (hint the flex design). Perhaps wrapping it NOT too tight will be okay? Does it make at big different in noise reduction if the flex-section is wrapped? I wrapped my y-pipe too but not at the flex-section because of that reason.
Old Feb 17, 2004 | 07:34 AM
if you can bend the ypipe a little at the flex section after you wrap it, you should be fine. I think it needs to flex not because of exhaust pressure but to reduce stress on the cat. Everything is on rubber hanger after the Cat and they are made to be loose a little. Without the flex section, you will put a lot of stress on the cat and the connection between the cat and the ypipe.
I took off the ypipe last year to check the flex section and I re-wrapped the pipe again without wrappin the flex. I couldnt tell if there's any increase in noise.
Old Feb 17, 2004 | 08:45 AM
VMaximus02's Avatar
Well, I am basically saying the same thing. The exhaust pressure = vibration is the source of stress on the cat. (ceramic substrate inside).
Old Feb 17, 2004 | 09:31 AM
in my case, the vibration is mostly from road condition.
Justin Kroll
Oct 1, 2015 07:03 PM
09maxshawn11
Sep 30, 2015 10:28 AM
Socalstillen
Sep 26, 2015 12:01 PM
jerrod99_se-l
Sep 6, 2015 08:58 PM
