Stripped Manual Transmission Drain Plug...HELP!!!
Old Feb 17, 2004 | 07:29 PM
Komax's Avatar
So I bought Redline MT-90 and couldn't wait to change the oil...been a while. I realized that the drain bolt was a bit rusty. It's hard to get to because of this metal beam that gets in the way. I couldn't use a socket wrench. As I started to loosen it, it stripped! I sprayd PB Buster and WD-40 but it wouldn't budge. The bolt stripped and now I feel lost.
How can I remove this stripped bolt? What should I do?
Old Feb 17, 2004 | 08:37 PM
5 spd's Avatar
I haven't looked underneath my vehicle yet, since I have just bought it, but what type of bolt is this? is the head a hex head or a drain plug type where you put in a half inch drive ratchet and turn?
Old Feb 17, 2004 | 08:41 PM
Komax's Avatar
There are 2 bolts: a drain plug at the bottom of the tranny and the bigger fill bolt that uses a 1/2" socket to open.
The drain plug is a regular 12mm bolt that got stripped.
Old Feb 17, 2004 | 09:07 PM
PhatMax's Avatar
First: Go to the dealer and buy a replacement plug/gasket.
Second: Go to Home Depot/Sears/Lowe's and get a really good 12mm box wrench (for your lovely new plug), a pair of honest-to-god Vise-Grips (maybe the narrow jaw to fit) and a small, 1/4" square, agressive metal file.
Third: Go home, Get under, File two opposing sides of the bolt head flat, lock the hell out of the Vise-grips on the newly square bolt, and turn. Drain tranny oil into pan, place new plug in hole, and torque to ~14 Ft lb with your new 12mm wrench. Find another 12mm bolt to test your torque value on so you can get the feel when you do it without a torque wrench. Refill tranny.
Good Luck!
Old Feb 17, 2004 | 09:37 PM
Komax's Avatar
Good Luck!
Wow. Thank you VERY much!
I'll try that!
Old Feb 17, 2004 | 11:11 PM
bsetiawan's Avatar
I've stripped mine twice already and everytime it's really rounded. First of all I removed the bracket that holds the shifter rod, then I used needle file to slowly file it back to shape. Then I used a 6 point socket to remove it. Sometimes I wonder if it's the bolt that's not manufactured to spec or my Craftsman wrench that's defect.
Old Feb 18, 2004 | 04:12 AM
silentbuzz's Avatar
You can always spot weld your wrench to teh bolt.
Old Feb 18, 2004 | 05:53 AM
bsetiawan's Avatar
That drain plug bolt was soft like a butter. I don't think it's a good idea to spot weld it.
Old Feb 18, 2004 | 05:57 AM
spirilis's Avatar
I used the reverse switch to drain mine... didn't even see the "drain plug"
Old Feb 18, 2004 | 05:59 AM
naerok's Avatar
im about to do my transmission change also....
is the drain plug the one with the sensor??
Old Feb 18, 2004 | 07:19 AM
Krash513's Avatar
Go to your local sears and get a "bolt out" kit Every time ive had a bolt round off or be rusted on, this thing gets it right out. It digs into the bolt to help it out.
user 11122324
42
Jul 18, 2022 03:35 PM
doctorpullit
Oct 28, 2019 10:58 PM
Forge277
Jun 13, 2016 09:26 PM
Pied
Sep 26, 2015 03:29 PM
