Post Springs Install Question
Old Feb 20, 2004 | 07:52 AM
Ammi's Avatar
350 Detroit Muscle
When I turn the steering wheel when car is moving slowly, sometimes I hear some popping noise coming from the front. Where is that noise coming from? I never had any noise problems before when I installed aftermarket springs.
Old Feb 20, 2004 | 08:59 AM
BigDogJonx's Avatar
Was the spring intstalled correctly on the perch's? Maybe it has come loose and when you turn the wheel, the spring is turning as well and poping out out or into that perch.
Dixit
Old Feb 20, 2004 | 09:15 AM
limsandy's Avatar
Re-seat the springs on the strut and the noise should go away if you do it correctly. Good luck.
~limsandy
Old Feb 20, 2004 | 09:54 AM
Ammi's Avatar
350 Detroit Muscle
I made sure 3 times that the spring was well seated on the strut before I uncompressed the spring.
Man...........I just got a wheel alignment too
Old Feb 20, 2004 | 11:48 AM
ChillWill2000's Avatar
if you have Tein s-tech and didnt trim the bottom of your bump stop Then its probably your bump stop on the strut. laterz
Old Feb 20, 2004 | 11:51 AM
Ammi's Avatar
350 Detroit Muscle
I haven't had any problems going back and forth between my Eibach and Teins using same bumpstop.
Old Feb 20, 2004 | 12:04 PM
2k1IceMax's Avatar
When you put the springs in did you make sure that the "OUT" stamped in the tophat was pointing away from the car. When I put H&Rs in my 01 SE mine made a popping noise when turning. When I went back in to put my struts in I noticed the "OUT" stamping was pointing back toward the firewall. I put it back in correctly and everything is quiet now.
Old Mar 29, 2004 | 11:00 PM
housecor's Avatar
Hate to resurrect a dead thread, but Ammi, did you ever solve this?
Old Mar 29, 2004 | 11:04 PM
Ammi's Avatar
350 Detroit Muscle
Yeap. Problem went awayafter I've put some miles on my springs. Springs just needed to settle.
dank4us
34
Jun 10, 2024 03:45 AM
max_speed97
Aug 26, 2015 07:46 PM
Economic_Rage
Aug 20, 2015 08:27 AM
mikekay
Aug 10, 2015 12:52 PM
kirkhilles
Aug 8, 2015 10:53 AM
