Berk Intake + Apexi Filter Install Question
Old Feb 21, 2004 | 09:56 AM
CCx's Avatar
CCx
I'm not too much of an idiot, but for those who have this setup -- how in the H3LL did you get the silicone hose over the Apexi adaptor - it slips right onto the aluminum MAF adaptor but the other side will not fit over the thick metal of the Apexi adaptor -- I even tried microwaving it for a minute to heat it up, and that did not work either - any suggestions are appeciated!
Thanks in advance.
Old Feb 21, 2004 | 10:50 AM
redstradic's Avatar
that is a major pain in the butt. i have the exact same setup and just put some grease on the inside of the coupler. you might to try some oil or chapstick if you dont have that. just a little though.
Old Feb 21, 2004 | 10:51 AM
CCx's Avatar
CCx
Cool, but how did you stretch it to fit it over the Apexi adaptor? I can get about 5/8 of the coupler over the adaptor, but trying to stretch the rest to fit over it is almost impossible! Thanks
Old Feb 21, 2004 | 11:04 AM
redstradic's Avatar
like i said, grease and then it helps that i workout everyday. lol. i know what you are going through though. it was a b1tch to get that on and the one that goes on the MAF tube.
make sure you have the right couplers in the right spot.
Old Feb 21, 2004 | 11:40 AM
Virus's Avatar
I just got my Berk silicone couplers today. 1 is shorter than the other 2. Where does the short one go?
Old Feb 21, 2004 | 11:43 AM
CCx's Avatar
CCx
From the picture I would say the short one goes all the way to the left, the longer one would go on the right and then the smaller--->bigger coupler goes in the middle. Is this correct redstratic?
Old Feb 21, 2004 | 12:09 PM
redstradic's Avatar
you better believe it!
Old Feb 21, 2004 | 04:50 PM
Virus's Avatar
Bryan just informed me that the smallest one goes to the Apexi filter and the longer ones attach directly to the midpipe from both sides.
Old Feb 21, 2004 | 05:55 PM
92 SE-R 02 SE
wow BERK looks alot like frankencar...........
Old Feb 21, 2004 | 06:00 PM
scopium
hahah.. i had that problem.. its takes patients
what i did is take the silicone and put it in microwave for about a minute..
then as soon as i took it out i streched it with my hands a bit and i try to fit in in the maf by pushin down and twisting.. took me about 30 min to get it in
Old Feb 21, 2004 | 07:43 PM
CCx's Avatar
CCx
Bryan's sending me a new adaptor -- apparently the genuine Apexi one he sent me is 3.25" on the outside (probably why the 3" coupler wouldn't fit on, I even lifted weights a few times this evening and then tried to get it on! ) -- he has a different adapter that he is sending me that will definitely fit, another example of how Bryan is committed to his customers! Thanks for all of the help guys, I definitely appreciate it! Hopefully it'll be above 50 degrees again soon so I can take another crack at installing this bad boy
Old Feb 22, 2004 | 03:15 PM
Virus's Avatar
Holy Mary mother of God was it a pain in the ars to get those silicone couplers on both the MAF and the Intake Manifold. Good new is that KY Jelly can be used for things other than sex I tried a flat head screwdriver after heating it up for 1 minute and it started to dig into the plastic MAF. I had my wife hold the MAF while I twisted and it finally went on. It's not coming off! I tried like the ****ens to get it on the intake manifold without success. I knew it was going to be hard as the FrankenCraps were, but the FrankenCraps weren't this hard. I didn't have any chapstick or vaseline, but I did have a 2 year old tube of KY. I put just a tad on the end, inside and out and it went on somewhat easy.
Old Feb 22, 2004 | 07:41 PM
Trance Artur's Avatar
where do you guys buy the berk intake?
Old Feb 22, 2004 | 08:23 PM
Virus's Avatar
In the Group Deal forum. You better jump on it immediately. Although, as mentioned it won't give you any more hp than the FrankenCar, it just looks alot better. Berk has the Apexi filter at an awesome price.
http://forums.maxima.org/showthread.php?t=273626
95Maxi
Aug 29, 2015 09:38 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Maxboy23
Aug 11, 2015 11:59 AM
kirkhilles
Aug 8, 2015 10:53 AM
