Bose w/ aftermarket system
Old Feb 22, 2004 | 06:37 PM
SE01's Avatar
I just purchased my 01 SE and it has the Bose system in it. I have 2 Rockford Fosgate 10" HX2's with a RF 750S amp from my old truck and I want to add it to the Bose system. I tried using the search feature but it wouldn't let me search. Can anyone tell me how it would sound if I added my subs to the Bose. Does anyone have a link on the directions how to do it? Any opinions on doing this? All welcome.
Old Feb 22, 2004 | 07:03 PM
studman's Avatar
Read the Audio Forum's FAQ. Your answer is in there.
Old Feb 22, 2004 | 07:09 PM
NYC2SD's Avatar
I have an Eclipse 12 .Sounds pretty good, but make sure to dynamat like crazy.
Old Feb 22, 2004 | 07:27 PM
PearlWhtMaX2000's Avatar
i have 2 12's in the back, and it sounds good. you should be fine
Old Feb 22, 2004 | 08:14 PM
studman's Avatar
Oh, and where to dynamat..... here's a good tip....
When you lay down the back seats of your car, you see that nice little black plastic trim that covers the pass through (on the cabin side of the pass through)....... PULL THAT OFF and dynamat the BACK of the plastic. That stuff rattles like crazy. I used a truck pack of Dynamat Extreme to do it, but I only have it and one small triangle on the trunk done, and it stopped about 98% of all my rattles.
Old Feb 22, 2004 | 11:08 PM
vqman
great advice!
I have a bulk pack of xtreme (36 square feet) and needed to know some good places to put it!
any other suggestions?
-vq
Old Feb 23, 2004 | 01:06 AM
$tillenmax2k
I'd dynomat key areas in the trunk also to prevent vibration issues later on
Old Feb 23, 2004 | 08:27 AM
SE01's Avatar
Found all I needed, thanks.
Old Feb 23, 2004 | 10:19 AM
studman's Avatar
Start with the black plastic. Then use your ears to listen for vibration. Once you find the vibration, use your hands to apply minimal pressure to see if the vibration disappears. If so, DynoMat there.
This is for those who can't afford to DynoMat the entire trunk, but still want to get rid of the majority of the rattles.
Old Feb 23, 2004 | 10:24 AM
oakes57's Avatar
How much weight does a full trunk dynomated add?
bigdo26's Avatar
I think I need to get another round of dynamat... thanks for the tips on what rattles, i've tried to find key spots and managed to get some, but there are still several around. I'll try doin that black trip soon
9aj9
Apr 5, 2020 12:11 AM
Mar 12, 2020 12:06 AM
A32goldylocks
Sep 2, 2015 06:39 AM
