side corners
Old Feb 22, 2004 | 08:25 PM
maximillus's Avatar
side corners
does anyone know how to make the side corners blink when u turn on da turn signal?
Old Feb 22, 2004 | 08:27 PM
Ammi's Avatar
350 Detroit Muscle
read the "How-To's"
Old Feb 22, 2004 | 08:31 PM
blue2k2's Avatar
is it just me, or do a lot of these new threads seem to be about stuff that was just talked about in very recent threads
Old Feb 22, 2004 | 08:33 PM
Ammi's Avatar
350 Detroit Muscle
Yeap. It seems that way
Old Feb 22, 2004 | 08:52 PM
maximillus's Avatar
sorry but i went to the "how-to's and none of the links work for me so if anyone can help
Old Feb 23, 2004 | 06:15 AM
2k3TEMaxSE's Avatar
How-To: Sidemarker ReWire
On the wiring for the side markers, cut the black wire in half. Take the end of tthe black wire that goes somewhere in the car, and tape it off - so that it doesn't touch anything (ground out). Connect the other side of the black wire that you cut with some wire of your own - no more than 3 feet in length. Run this wire up the inside of the fender to the headlight. Locate the two wires at the blinker in the headlight. Wire tap your wire that you ran into the (don't quote me on the color), but i believe it was a green striped wire - i'll double check for you tonight if i have time - but whatever wire is the negative terminal (the one that completes the circuit) at the blinker - is the wire that you want to use - but this is basically all that you have to do to get them to blink.
Note:
With the headlights off - the corners blink with the headlight blinker.
With the headlights on - the corners blink alternately with the headlight blinkers.
Just FYI
Old Feb 23, 2004 | 11:58 AM
fishhouse's Avatar
how to is here:
http://www.max-world.org/frames/howtodo.html
look under "lighting" then "rewiring your front and rear...."
PLEASE NOTE:
there is an error in this how-to! DO NOT use the BLACK wire for the REAR! use the green wire instead!QUOTE]
user 11122324
42
Jul 18, 2022 03:35 PM
bigdogsteve
Jan 31, 2018 04:18 PM
knight_yyz
Nov 1, 2015 01:34 PM
Noela
Sep 26, 2015 08:22 AM
