How do you install a side veiw mirror?
Old Feb 24, 2004 | 11:17 AM
ManualMaxima's Avatar
5th Gen till she dies!
i busted the mirror on my 2001 maxima, and i finally bought a replacemnet. How do you isntall it? i can prob do it i just want to make sure i do it correctly. is therea site of anything?
Old Feb 24, 2004 | 12:38 PM
01SE02SER's Avatar
Faster than a speeding bullet...
Unfortunately, you will need to remove the entire door trim/finisher to get to the side mirror assembly.
Here are the instructions as written in the Electronic Service Manual. I pieced the part about the door trim and the mirror assembly together for you...
Front Door Finisher
1. Remove inside handle escutcheon.
2. Remove screw securing pull handle, and then remove pull handle.
3. Remove power window switch finisher, then disconnect the connectors.
4. Remove mask securing front door finisher.
5. Remove screw securing front door finisher.
6. Remove clips securing front door finisher.
7. Lift out front door finisher. Disconnect harness connectors.
Door Mirror Assembly
8. Remove inner cover front corner of door.
9. Disconnect door mirror harness connector.
10. Remove door mirror harness clips.
11. Remove bolts securing door mirror assembly.
Good luck. Peace.
Old Feb 24, 2004 | 02:57 PM
K Pazzo 6's Avatar
yes what he said....its very easy....i've done it twice
Old Feb 27, 2004 | 07:33 PM
custommaximaSE's Avatar
It sound easy
but we need it with pictures.
vingodine
45
May 21, 2016 12:46 PM
JRod28
Feb 4, 2016 11:07 AM
rtirbany
Sep 8, 2015 11:46 AM
wpr
Aug 5, 2015 03:28 AM
