Resonator loose....
Old Feb 26, 2004 | 04:19 PM
2k5spd's Avatar
Silencer loose....
i was taking out my elbow from the silencer to the air box. when i remove
that elbow, the silencer is loose. is this normal? i don't recall it being
loose before.
edit: i meant silencer, i think.
Old Feb 26, 2004 | 04:27 PM
TZapper's Avatar
Originally Posted by 2k5spd
i was taking out my elbow from the res. to the air box. when i remove
that elbow, the res box is loose. is this normal? i don't recall it being
loose before.
is it the box that is (was) connected to the intake box, which sits in front of the engine bay with a vacuum-style flat wide hole to suck air into and has some temp boost sensor or whatever it is called? If yes than mine is loose too.
Old Feb 26, 2004 | 04:30 PM
2k5spd's Avatar
i think so. white box, sits under and in front of the battery.
Old Feb 26, 2004 | 06:05 PM
ChromeSE5's Avatar
Just rip out the white box... thats what i did to mine from underneath my car. Waste of space IMO.
Old Feb 27, 2004 | 10:11 AM
2k5spd's Avatar
bump.......
Old Feb 27, 2004 | 10:23 AM
spirilis's Avatar
Everything upstream the airbox is loose. White box, 90-degree elbow, the "ramscoop" inlet, etc...
I ripped it all out
(well, except for the white box, which I should rip out just for spaciousness since it's not in use)
Old Feb 27, 2004 | 10:24 AM
spirilis's Avatar
I ripped it all out
Only possible side-effect I've seen is a small loss of low-end torque, especially when it's hot outside (since it becomes a warm-air intake afterwards)
Solution? Eventually I'll put a PR CAI in there
Old Feb 27, 2004 | 10:50 AM
2k5spd's Avatar
wouldn't you eliminate that by just routing a hose from the bottom of the airbox (where the elbow used to insert) to the fender? ala oscai?
BkGreen97
Apr 2, 2016 05:47 AM
Maxboy23
Sep 4, 2015 06:04 PM
mpbclutch33
Sep 1, 2015 09:24 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
george__
Aug 15, 2015 07:24 PM
