Clearing ABS light
Old Feb 28, 2004 | 10:50 PM
piotroosh's Avatar
Clearing ABS light sensor replaced
Hi
i had bad front right ABS sensor, and my ABS didn't work. I replaced that sensor, but the ABS light went off. Is there any way to clear it? (ABS are working now).
Pete
PS. Wanted to look in archives but search does not work.
Old Feb 29, 2004 | 08:38 AM
piotroosh's Avatar
Ok got some more info ... when i dosconnect the sensor... ABS light is off.. but ABS does not work... when i reconnect the sensor. ABS is working fine, but light is on. Doesnot make any sense to me.. ;-) anyone?
Old Feb 29, 2004 | 11:39 AM
Zero Deuce SE's Avatar
How far did you drive the car after you replaced the sensor?
Old Mar 1, 2004 | 04:42 AM
piotroosh's Avatar
right now is second day... +/- 50 miles.
Old Mar 1, 2004 | 07:04 AM
Did you clear the code by disconnecting the battery for a few minutes?
Old Mar 1, 2004 | 07:15 AM
piotroosh's Avatar
yes, i disconencted battery for 25 minutes.. light still on. the weird part is, that when I unplug the sensor, it is not on ;-)
is there any way to clear the light with some "key / ignition combination" ? I saw some way to clear Airbag light... is there such a thing for abs?
Old Mar 3, 2004 | 04:00 AM
I guess there may be something else wrong with your ABS then. I would take it to the dealer to have it diagnosed with the Consult-II. Just get them to tell you what the problem is before they try to fix it. You might or might not be able to fix it yourself.
mvm062
Nov 30, 2020 09:00 AM
markevans999
Sep 10, 2015 04:29 PM
Maxima30
Sep 7, 2015 06:13 PM
JoshG
Sep 5, 2015 10:10 PM
maximusrising
Sep 2, 2015 09:55 AM
