Where is the antenna on my car?
Old Mar 2, 2004 | 05:55 PM
5 spd's Avatar
I just noticed that I dont have an antenna growing on the tops surface of my car. where is it at? integrated in the windshield?
Old Mar 2, 2004 | 05:58 PM
maximadave's Avatar
detailerdaveb@gmail.com
integrated in your rear window
bert's Avatar
Lower passenger side of the rear window.
Old Mar 2, 2004 | 06:05 PM
BP's Avatar
BP
i always thought it was integrated into the rear window as well.
Old Mar 2, 2004 | 06:08 PM
5 spd's Avatar
I am never back there, so I have never bothered to look back there...
Old Mar 2, 2004 | 06:17 PM
2k3TitaniumSe's Avatar
WTG Nissan!
Old Mar 2, 2004 | 07:28 PM
gsumax's Avatar
its probably the biggest piece of **** antenna ever made
Old Mar 2, 2004 | 07:34 PM
BioMaxDDS's Avatar
i thought i'm listening to static noise hits everyday
Old Mar 2, 2004 | 09:11 PM
† ErV †
it's probably your metallic tint. mine works like it's a 20 foot pole, and i am way outside the atl where most stations broadcast from.
Old Mar 2, 2004 | 09:37 PM
BioMaxDDS's Avatar
i have metallic tint?
Old Mar 2, 2004 | 10:43 PM
dmplus's Avatar
Correct me if im wrong but i was informed that there are actually two antennas in the rear windshield, one at the top that takes most of the width, and the one in the corner. ?? Had to do something with a diversity system or something like that.
Old Mar 2, 2004 | 11:31 PM
† ErV †
it doesn't have to look metallic, if it contains metal instead of dye (or a combo of both) that could mess up the reception. i can think of no other reason...
Old Mar 3, 2004 | 03:15 AM
Zero Deuce SE's Avatar
I never have any problems with clear reception. It works just as good as my 92 SE that had the electric telescoping antenna along with the rear window antenna.
Old Mar 3, 2004 | 07:23 AM
gsumax's Avatar
mine really worked fine with the stock headunit. Its when i put the aftermarket cd player that it went bad.....
Old Mar 3, 2004 | 08:29 AM
spirilis's Avatar
The stock Nissan Diversity antenna system works great with the stock headunit, but when you use an aftermarket headunit that's not designed for it, it sucks ***. It uses a 2-antenna system with 2 signals in the connector, which you need an adapter to hook up to standard aftermarket headunits (which accept 1 signal input)
Old Mar 3, 2004 | 08:36 AM
gsumax's Avatar
ha, thats why then, it went to hell with my aftermarket cd player
Old Mar 3, 2004 | 09:25 AM
BLKMAX005SPD's Avatar
**** are you serious...
i hate my stock bose stereo...i can't wait to put my dvd player in...
does it really suck that bad?
Old Mar 3, 2004 | 09:28 AM
Okay, I see what you mean now.
Old Mar 3, 2004 | 09:29 AM
gsumax's Avatar
yeah dude, i put in a screen too, and everytime i run under like a power line or soemthing it messes up, and its just terrible reception. Ive completely stopped listening to the radio, guess i need to get XM
Old Mar 3, 2004 | 12:36 PM
SEDaveMax's Avatar
Has anyone come up with a solution for the **** poor reception for aftermarket headunits? Seems that I only get a good strong signal if I am parked out in front of a 50,000 watt station. I also have the adapter.
Dave
02 Maxima SE w/Alpine
Old Mar 3, 2004 | 12:40 PM
E55AMG2's Avatar
Wat
it actually starts in the top of the rear window and goes down, then splits. Its a diversity antenna. It uses the heater elements for "added" reception.
Old Mar 3, 2004 | 12:46 PM
FanaticMadMax's Avatar
Never had any problem with my reception. There are two antenna. One is a primary and the other called the diversity.
Old Mar 3, 2004 | 12:54 PM
spirilis's Avatar
NOTE: The Power Antenna line must be activated for you to receive adequate reception. Be sure that is hooked up on the back of your headunit.
With the Power Antenna line hooked up, reception is "adequate", but noticeably worse in fringe areas than the stock headunit...
I don't particularly care since I rarely listen to the radio, and it works pretty well when I'm in sufficient range (i.e. not 30 miles away )
Old Mar 3, 2004 | 12:59 PM
2MuchMAX4U's Avatar
I just put in a new CD HU but had really bad reception at first but after doing some research I found that my problem was caused by.....
NOT CONNECTING THE POWER ANT LEAD
on the harnesses (aftermarket to new HU).
Apparantly the even though our cars don't have power ant they do still use the power ant lead (blue wire) for power for a reception amp or something.
I connected the wires together (I just taped them off 1st) and my reception was instantly better.
Before I had ok reception but when I drove the signal faded, etc.
Hope this helps anyone, it sure helped me and the HU sounds sooo much better than stock non bose!
Good Luck
Robert
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
98nismomax
Aug 13, 2015 12:44 PM
Balkins
Aug 12, 2015 06:39 AM
