Single G35C/350Z muffler on 2k2/2k3?
Old Mar 3, 2004 | 05:51 PM
Lumbee1's Avatar
I pulled up to an intersection and spotted two G35Coupes in the opposite lanes. When the light turned green, they both took off like they had a friendly competion. The exhaust tone from both of them running to redline was awesome. I know the G35C/350Z had dual exhaust, but is it possible to take one muffler and replace the stock one on the Maxima with it? Would the exhaust sound the same as the G35C/350Z? Am i just dreaming the impossible? I would rather have one of these because I know that they are built much better than most aftermarkets and there is less of a chance of in-cablin droning (Nissan would try and eliminate annoying sounds with their design).
Old Mar 3, 2004 | 05:58 PM
Ferbs02SMMax's Avatar
I have no idea whether the exhaust note can be duplicated on a single exhaust as in our 5th gens, but I second your idea. The exhaust note on the G35C (haven't heard 350Z too closely yet) is music to my ears, its lusty deep growl is outstanding. If I could change anything on my Max, it would definitely be rwd, but the exhaust would definitely go dual, with identical exhaust tone as the G35C. Bad-a$$!
Old Mar 3, 2004 | 05:59 PM
Deagle's Avatar
wants the ads to die
I was wondering the same thing. Any input would be cool.
Old Mar 3, 2004 | 06:14 PM
Lumbee1's Avatar
Don't ever get behind a FX35 or 45. They have a wicked exhaust note as well.
I got stuck in traffic behind a FX35. I kept hearing this sweet purr but couldn't figure out where it was coming from. Traffic cleared up and the FX35 pulled into the free lane and got on it. It quickly came to my attention exactly where the sound was coming from.
Old Mar 3, 2004 | 06:32 PM
Mass_Media's Avatar
Mass_Media™
FX45 V-8 power and that exhaust ahhhhh.......heavenly
Old Mar 3, 2004 | 06:35 PM
NizanDrivn's Avatar
What you gain in a different, more aggressive exhaust note, you'll lose in performance....2k2/3's have variable exhaust muffler stock....
The resonators are different, therefore diff sound...the maxima DOES sound like the infinities, just not as loud....
Infinities have a mean friggin' sound when you jump on the accel....
Old Mar 3, 2004 | 07:42 PM
JeepRage's Avatar
No, it will not work. The Z muffler is full width of rear bumper, the dual exhaust tips you see come out of either side of the muffler. It is a single muffler so taking it and trying to apply it to a single exhaust exit system would not work. I agree it sounds good, luckily I get to hear it every day.
Old Mar 3, 2004 | 08:10 PM
Hamy's Avatar
Its not going to work at all....like Jeep said, the G35C/350Z exhaust is the full length of the rear end. The sound is so very sweet, but its not going to work unless you work some trick custom setup.
Old Mar 3, 2004 | 08:56 PM
E55AMG2's Avatar
Wat
You can get the rear section, and have it sawed off and welded in place of the stock muffler. As for the note, it will sound different in that it should be slightly higher in pitch and tone. The reason why they sound so weird is that you are hearing 3 cylinders from each pipe. The full width muffler is actually just a can with each pipe goin thru it, crossing over sides). If it could fit, it wouldnt sound right at all, also youd have to plug one of the holes and run a length of pipe for it to come out in the right location. As for performance gains or losses, you wont see any, Even if it bolted right up. There really isnt a way for our maximas to get that sound. If you like that tone, I suggest a greddy evo. That is the closest our cars can get to the G35c/Z
Old Mar 3, 2004 | 08:58 PM
Cubanato's Avatar
Joo wanna play??......ok we go to war
no no no thats apples and oranges you cant compare the tone of a G35 coupe to Greddy....greddy i sloud as hell G35 coupse is not
-J
Old Mar 4, 2004 | 08:18 AM
E55AMG2's Avatar
Wat
I said its the CLOSEST thing we can get to. Also, if you just use the rear section, it wont be. The TONE is correct, the VOLUME is not. Read my post next time.
Old Mar 4, 2004 | 08:39 AM
Cubanato's Avatar
i just think that the frankencar cat-back would b the cloest tone and volume to the G35 coupe sound
-J
Old Mar 4, 2004 | 09:06 AM
DAVEB's Avatar
I've got a brand-new take-off I could sell you cheap- If you wanted to do the hack-n-cut thing.
Old Mar 4, 2004 | 09:44 AM
tedsmax's Avatar
Don't run a dual as a single
You will have very high backpressure. Backpressure from a muffler is proportional to exhaust flow velocity squared. True dual exhasust mufflers are typically more restictive than a single exhaust muffler. The advantage is that since it is dual, the velocity is cut in half so the velocity squared is 1/4. This means that duals can be twice as restrictive and still have half of the backpressure compared to a single. They ussually take some of the available restiction on duals and use it for sound tuning. Dual exhaust mufflers run as duals have less backpressure than a single, but a dual exhaust muffler run as a single will have more backpressure than a single exhaust muffler run single.
Ted
Old Mar 4, 2004 | 09:52 AM
MannyNJ2k2max's Avatar
you should hear the M45 @ WOT....you'd shyt yourself....
Old Mar 4, 2004 | 10:14 AM
MONTE 01&97 SE's Avatar
Your right I compared the sounds of the engines not exhaust during acceleration and my Max sounds very similiar to the 350, but once you throw in the resonation from the exhaust they are different.
Old Mar 4, 2004 | 10:26 AM
MaxSE03's Avatar
The GReddy is loud as hell compared to what? A stock car? The GReddy is actually somewhat quiet compared to most other cars with an aftermarket exhaust. My Eclipse with a GReddy Evo was twice as loud as the Maxima. You will not find any other exhaust that will sound closer to the 350Z.
Old Mar 4, 2004 | 03:19 PM
trey
that 350z sounds is soooo damn nice, I really don't feel like messing with my exhaust though, unless there was some kind of group deal ahha
Old Mar 4, 2004 | 06:05 PM
2k3TitaniumSe's Avatar
I wanna give it a custom try though. Maybe I'll be the first one to do it!
matts95max
Apr 23, 2025 10:44 AM
DJLAX152
May 4, 2021 11:46 AM
spazma7ik
Jan 12, 2017 09:38 PM
Max139617
Sep 29, 2015 06:44 PM
TheMafia
Sep 4, 2015 08:26 AM
