6-speed Manual tranny guys step in.
Old Mar 4, 2004 | 11:32 AM
Fezzik's Avatar
Ok. i need to know some info. I am sending some info out to see if a company will work on a sts for us 6-speeds.
We have a reverse lock, but how does it work. Please be detailed. Also is it a rod- or cable-type shifter.
Old Mar 4, 2004 | 11:44 AM
PoLo's Avatar
2-Wheelin it...
the "technology" behind it is actually pretty dumb...the reverse lock is just a small nub that bangs against the base of the shifter area. and when you lift the reverse ****, you miss the base and it allows you to travel to the reverse area. if youw ere making an STS, the adjustment would prolly be having a shorter ****. basically the **** would only go as high as where the new STS **** sits and lifting it would still bypass the base. you got a 6speed. take off your shift boot and look. it's so obvious once you look at it. taking off the boot is easy. just pull and it pops out.
Old Mar 4, 2004 | 01:06 PM
Fezzik's Avatar
thanks for answering that question. how about the question of if its either a rod or cable -type shifter.
Old Mar 4, 2004 | 03:07 PM
PoLo's Avatar
2-Wheelin it...
rod...it's tricky cause you'll have to have a pivot int he middle, plus probably ANOTHER base or bracket to keep the pivot from flopping around. the rod still needs to reach it's contact points which represent the gears. this should be interesting...i'd be very interested in this product. mossy was supposedly on this but it seems they laid off it....how many of us 6speeders would jump on this, i can only imagine.
Old Mar 4, 2004 | 05:37 PM
IWNTMORHP!!'s Avatar
CAN YOU PUT IT ON THE WALL?
i would, especially if it smoothed the shifts out. i hate how notchy our throws are.
Old Mar 4, 2004 | 06:10 PM
Fezzik's Avatar
I know. i've been trying to tell em this. I think just about every 6 speed owner would jump on this if one comes out.
Old Mar 4, 2004 | 08:52 PM
maximadave's Avatar
detailerdaveb@gmail.com
I would definately jump on it once it comes out
Old Mar 4, 2004 | 09:22 PM
ABS's Avatar
ABS
Not to argue, but the fact is that the 6 speed tranny has a cable shifter (two cables in fact) and not a rod shifter at all.
Old Mar 4, 2004 | 10:10 PM
Fezzik's Avatar
Are you sure. i dont know and need to confirm this soon.
Old Apr 15, 2004 | 03:57 AM
whats the story...anyone getting anywhere on this? it would be a godsend if we could get one made! i am working with nissan to get my tranny replaced already and i have 38k on the odo, and it shifts really hard...oh, was it rod or cable? thanks guys and keep working on this...PLEASE!!!
Old Apr 15, 2004 | 05:18 AM
3Pedals_6Speeds's Avatar
The shifter is attached to a rod assembly up in the cockpit where we can see it. If that rod somehow attaches to a cable then maybe it's cable, but from what you can see when you remove the shift boot, it appears to be a rod system.
Old Apr 15, 2004 | 06:17 AM
Kojiro_FtT's Avatar
Dude, take your dash apart and take some pictures and send them to the shop. They will need more info than just wether or not it's a cable or rod shifter anyways. Let them figure it out from the pics, they are the experts.
Old Apr 15, 2004 | 07:42 AM
Bluesbrekr's Avatar
Doctorate in Detailing
It's a cable shifter. I just checked my FSM. There are 2 cables, in fact. A 'shift' cable and a 'select' cable. I'd post a pic, but I can't select only that page. Maybe someone else can? It's page MT-11 in the FSM.
Old Apr 15, 2004 | 08:50 AM
SteveSE's Avatar
it is a cable actuated shifter, although the cable can't be seen by just pulling up the shift boot. I posted a thread on this a few days ago and got next to zero interest or input. Try calling someone that makes the shifter shown here http://forums.maxima.org/showthread.php?t=302126 , it couldn't be too hard to adapt and sell for us.
Old Apr 15, 2004 | 09:23 AM
housecor's Avatar
I don't see a cable. I see a rod. Not claiming to be an expert here, but here's shot if this helps:
Old Apr 15, 2004 | 10:23 AM
Dave B's Avatar
Not DAVEB the parts guy
It's cable shifter. What you are seeing in the pics is a actuating rod. A few inches further up is where the rod connects to the cables.
Dave
mclasser
Aug 23, 2015 09:32 PM
maxipower
Aug 21, 2015 11:10 AM
maxinout93
Aug 20, 2015 02:17 AM
mikekay
Aug 10, 2015 12:52 PM
kirkhilles
Aug 8, 2015 10:53 AM
