people who have lowered..how's your tires?
Old Mar 4, 2004 | 12:04 PM
mistermax's Avatar
just wanted to know how a drop will affect the tire wear or uneven tire wear. i had a integra gsr before my max and it was lowered 1.5 in all around on eibachs and my tires got owned by negative camber wear quickly and the insides of the front tires were bald as mr. clean and got there fairly quickly. is there any way to prevent this? is it a big problem with the maximas with a drop? what camber kits are available?
Old Mar 4, 2004 | 12:34 PM
NT2SHBBY
an alignment is your best friend
Old Mar 4, 2004 | 01:24 PM
[maxi-overdose]'s Avatar
depends on how much drop you want. I would say with the available lowering springs for maxima, people dont really have uneven wear unless the alginment is off after the install. I have eibach prokit and after 35k miles of riding it, I dont have any problem with uneven tire wear. You probably had Eibach sportsline for your integra.
if you decided to lower it more with coilovers, you might need the camber plate.
Old Mar 4, 2004 | 01:28 PM
BLaZin 2k MaX's Avatar
I go through tires like I go through oil changes.
Old Mar 4, 2004 | 01:34 PM
MacAlert's Avatar
Speaking of alignment, I'm getting Maxspeeds installed sometime this month. Will I need an alignment and if I do, do I need a wheel alignment or camber and toe?
Old Mar 4, 2004 | 01:37 PM
NYC TAR's Avatar
any tips on doing that
Old Mar 4, 2004 | 01:58 PM
mistermax's Avatar
an alignment made no fix to the problem i had...the tires were still balding and wearing unevenly...i was really wondering about how the drop on tein s tech's would have on the tire wear as well.
Old Mar 4, 2004 | 02:04 PM
Ammi's Avatar
350 Detroit Muscle
You always get an alignment after you do suspension mod
Old Mar 4, 2004 | 02:17 PM
5thgen2nr's Avatar
It seems like I need new front tires every 10k miles, regardless of the brand, compound, or the way I drive. The rear tires barely wear at all
Old Mar 4, 2004 | 02:32 PM
Komax's Avatar
That's why they say rotate tires after every 5k miles.
Old Mar 4, 2004 | 02:46 PM
CCx's Avatar
CCx
I'm planning on lowering with H.Techs, and then putting my 19's on a week or two later. I don't want any alignment shop so much as breathing near my wheels, so will I be okay getting the alignment after my drop and before putting my wheels on? I guess what I'm asking is, will putting my larger wheels on after my post-drop alignment throw it back off at all? Thanks in advance for your answers.
something must be wrong. I still have the original tires on and I put ~50k miles on them. I do rotate them every ~7000 miles though.
what does everybody use to lower the car? I have koni and eibach and I have no alignment problem or uneven tire wear. The alignment after the install indicates the camber was off a little but everything else was fine.
Old Mar 4, 2004 | 03:59 PM
tkostiuk4's Avatar
I have had my Eibachs for roughly 6,000 miles. I got an alignment right after, and everything looked ok when I changed my oil after 3k. Just two weeks ago I was planning on changing my oil and doing a tire rotation, and when I got under the car to change the oil I noticed that my front tires were balding on the inside. I guess my question is, will a camber kit and another alignment fix the problem???? I really hope so becuase I don't want to buy another two tires in another 6k.
Old Mar 4, 2004 | 04:31 PM
Ammi's Avatar
350 Detroit Muscle
It shouldn't. I did the same thing. Had factory wheels on when I took my car in for a wheel alignment
Old Mar 4, 2004 | 04:32 PM
Ammi's Avatar
350 Detroit Muscle
Camber kit should take care of that problem.
Old Mar 4, 2004 | 04:37 PM
theMax's Avatar
Maxspeeds here for 25K miles with no abnormal wear of the tires and no alignment.
If you get an alignment this will fix the problem. Talk to the alignment person and if they don't have enough play to get a good alignment then you will need a camber kit to get an extra few degrees of movement.
Looks like people do not need extra camber adjustments until the drop is more than 2 inches.
Old Mar 4, 2004 | 05:04 PM
Bulldawg's Avatar
An alignment will not fix your camber problems if they are two far out of spec. The only way to avoid this is by
A) getting a camber kit, or
B) buying suspension setup that has pillow ball mounts(like mine, JIC FLT-A2).
There is no need for any camber kit or adjustment in the rear because of the multilink suspension crap, it all drops together (no pivot point).
Even if you don't drop your car very much, you should still get an alignment. Any time you change or adjust your suspension you should get an alignment, also need one when you get new tires.
Old Mar 4, 2004 | 08:34 PM
5thgen2nr's Avatar
The fact that I drive about 15 miles of curvy, pot-hole filled road every day might have something to do with my tire wear.
Old Mar 5, 2004 | 05:25 AM
Ammi's Avatar
350 Detroit Muscle
I think they are referring uneven as only the outside or the inside of the tire wears out.
Old Mar 5, 2004 | 05:36 AM
naerok's Avatar
you should get an alignment after your springs have settled... not right after you ahve installed it...
Old Mar 5, 2004 | 07:41 AM
TitaniuMax03's Avatar
the wear on the inside of my front 2 tires went bald fast, but the funny thing is the camber looks way off in the rear..like everyone else said "Alignment" or "Camber correction kit"..
litch
123
Jan 4, 2024 07:01 PM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Garrettz459
Sep 28, 2015 02:50 PM
