Popping sound from front driver side strut
I just had Tein H-Tech and Tokico illumina struts installed and I am getting a sort of popping sound out of the front driver side strut whenever I turn. Shop said to give it some time to seat and it should go away. Well, it's been 8 days now and I've driven probably 300 miles and it's still there. I'm gonna take it back and let them look at it but does anyone have any ideas what it is and why it's doing this? Thanks
strut noise
8 days seems like a tad to long for the struts to seat. Banging like that is probably a faulty install. I had the exact thing happen when I installed my illuminas. What I was told by fellow members was that on the strut cap there is the word OUT marked on it. Make sure when your shop reinstalled the strut, that this part faces outward (logical). Basically you should have your shop definitely redo the install. My noise is totally gone after I fixed it and the Max rides like a new car. Since you paid for the install, you can insist on getting the job done to your satisfaction. Good luck.
I think I can answer you this one, might have the same prob.
I had a brake job done at a local shop and a sound (popping) was coming from the front passenger side. I figured maybe the brakes were not installed correctly or something. A few days later, the sounds is still present and I take it back to them and they said the brakes were working fine and that the noise is coming from somthing else. It came from a loose control arm, the lower control arm. They tightened them for me and alas, its gone. Maybe thats your problem. have them inspect that.
BTW, the rear Illumina struts... is the piston rod supposed to be slightly off-center?
I was examining one of mine sitting in the basement this morning, and noticed the rear strut I picked up had its piston rod *almost* centered relative to the centerline of the strut housing, but it was slightly off...
i.e. if you looked at the strut from a sideways view, and rotated the whole housing around, you'd notice the piston rod protrudes at a slight angle...
I haven't compared the fronts or my other rear strut to see if this is a defect or if it's normal.
Originally Posted by looslip
This also happened to me when I installed my GR-2's. You just have to turn the strut so that the upper strut mount has the word "out" facing out.
Originally Posted by ChillWill2000
Do you think having it on backwards and driving around for a while will have ruined the strut? Because my left side clicked(popped) when I would turn the wheel- but i did it for like a week or 2 then went away.
This is kind of embarrassing but,
I installed lowering springs on my SAAB a while back and did not get the strut top bolt tight enough. I had some wicked knocking sounds until I pulled them off again and got the bolts tight.
kingw323
20
Oct 21, 2015 08:36 AM
KGMtech
Aug 18, 2015 09:21 AM
BassAddictJ
Aug 4, 2015 11:38 AM
